0.7.3 does not install [message #31884] |
Thu, 14 August 2008 13:37 |
Originally posted by: gregor.rosenauer.itsv.at
I have successfully (well, with some hickups when renaming files, but else
ok) used Subversive 0.7.1/Ganymede.
Now for some reason SVN-connectors disappeared and I cannot get them back
(I believe the problems started after installing the SQLExplorer-Plugin,
which I now uninstalled without effect).
I have read through the list and changed the URLs accordingly, but always
get errors that either some dependencies cannot be resolved, or the view
cannot be initialized.
When trying to update via the update sites, I get this:
Cannot complete the request. See the details.
Unsatisfied dependency:
[org.polarion.eclipse.team.svn.connector.svnkit.feature.grou p
2.0.3.I20080814-1500] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.2.I20080801-1500,1.0.0)
[org.polarion.eclipse.team.svn.connector.javahl.feature.grou p
[org.polarion.eclipse.team.svn.connector.feature.group
Unsatisfied dependency: [org.maven.ide.eclipse.feature.feature.group
0.9.5.20080717-1821] requiredCapability:
org.eclipse.equinox.p2.iu/org.maven.ide.components.maven_mod el_edit/[1.0.0.20080717-1819,1.0.0.20080717-1819]
org.eclipse.equinox.p2.iu/org.polarion.eclipse.team.svn.conn ector.feature.group/0.0.0
[org.polarion.eclipse.team.svn.connector.javahl.win32.featur e.group
From the archived site I get this, after the install runs through:
An error occurred during provisioning.
Failed to prepare partial IU: [R]org.eclipse.team.svn.core
0.7.3.I20080814-1500.
Please help, or else I have to go back to Subversive...,-)
Re: 0.7.3 does not install [message #31955 is a reply to message #31884] |
Thu, 14 August 2008 15:17 |
[Update] I removed all SVN/Polarion bundles from plugins/ and features/
(although I uninstalled them via p2 inside Eclipse, there were many
packages left), did an eclipse -clean but still face the same problems,
both with the online update sites and the archived site.
Re: 0.7.3 does not install [message #32374 is a reply to message #32304] |
Tue, 19 August 2008 16:01 |
Originally posted by: micky_lee.cyberpowersystems.com.tw
me too, I download all files and installed well, but when I create a new
SVN repository, it told me the following...
SVN: '0x00400006: Validate Repository Location' operation finished with
error: Selected SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available or install and select pure Java Subversion connector from the
plug-in connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Client.
but I download all native JavaHL 1.4.5 and 1.5 include others in
http://www.polarion.org/projects/subversive/download/eclipse /2.0/ganymede-site/
after all updated, the SVN connector still can't use....
I am very sad...
Re: 0.7.3 does not install [message #33933 is a reply to message #32374] |
Tue, 23 September 2008 14:53 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello micky,
You should install connectors from
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/,
because connectors from
are not compatible with SVN Team Provider 0.7.3.
For more details, please, see
http://www.eclipse.org/newsportal/article.php?id=701&gro up=eclipse.technology.subversive#701
"micky" <micky_lee@cyberpowersystems.com.tw> ???????/???????? ? ????????
?????????: news:8ae2a75caa9947fff998fd319935bdbd$1@www.eclipse.org...
> loaded.
> I am very sad...
FUDForum. Page generated in 0.27958 seconds
