Home » Eclipse Projects » DSDP - Target Management » Newb Troubles with Connecting to Server
Newb Troubles with Connecting to Server [message #31710] |
Wed, 11 February 2009 03:47 |
Dirk Messages: 5 Registered: July 2009 |
Good Evening,
I have only recently started using Eclipse (Version: 3.4.1) and I'm trying
to setup SSH or FTP (I'm not sure of the difference to be honest) onto a
school server that's running Fedora 9. I currently use two programs to
connect to the network. One is called SSH Secure File Transfer Client, and
the other is PuTTy. I would like to be able to have the functionality of
those two programs in Eclipse. I believe I have installed TM Stable Build:
3.1M5 by downloading the file, and extracting the contents into the
Eclipse install directory.
My troubles lie in setting up the connection. I have tried creating a New
Connection of type Linux, SSH Only, and Unix, but none of them work. I
enter the server name, but when I try to connect and enter in my user ID
and password, I get the following error message:
Operation failed with exception 'Session.connect:
java.security.NoSuchAlgorithmException: DH KeyPairGenerator not available'
I'm not sure what I'm doing wrong or if I'm even doing anything right.
Thanks for any help you can give, and let me know if you need anymore
information.
-Dirk
Re: Newb Troubles with Connecting to Server [message #31855 is a reply to message #31710] |
Mon, 16 February 2009 16:20 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hi Dirk,
it looks like your SSH server requires a Diffie-Hellman ("DH")
algorithm for encrypting your connection, and the Java JRE that
you are using doesn't have that installed.
Our SSH library, JSch, should support DH key exchange, so it looks
like your JRE is somehow incomplete or broken. I'd recommend installing
a new JRE (e.g. http://java.sun.com).
For reference, see also this:
http://sourceforge.net/mailarchive/forum.php?thread_name=DC5 D1608EE88544B9523CED8A7FA11682F95F184%40hxmb01.pnet.ch&f orum_name=jsch-users
and this:
http://www.jcraft.com/jsch/
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Dirk wrote:
> Good Evening,
> trying to setup SSH or FTP (I'm not sure of the difference to be honest)
> onto a school server that's running Fedora 9. I currently use two
> programs to connect to the network. One is called SSH Secure File
> Transfer Client, and the other is PuTTy. I would like to be able to have
> the functionality of those two programs in Eclipse. I believe I have
> installed TM Stable Build: 3.1M5 by downloading the file, and extracting
> the contents into the Eclipse install directory.
> New Connection of type Linux, SSH Only, and Unix, but none of them work.
> I enter the server name, but when I try to connect and enter in my user
> ID and password, I get the following error message:
> information.
> Cheers,
> -Dirk
Re: Newb Troubles with Connecting to Server [message #579012 is a reply to message #31710] |
Hi Dirk,
and this:
Dirk wrote:
> Good Evening,
> information.
> Cheers,
> -Dirk
Current Time: Fri Apr 26 05:01:34 GMT 2024
Powered by FUDForum. Page generated in 0.03051 seconds
