| Switching to debug perspective on suspend [message #313978] |
Thu, 29 March 2007 11:16  |
Originally posted by: matt.querix.com
Hi all,
I have just implemented debugging for our language in Eclipse. When a
program hits a breakpoint and suspends in my language, the user is not
asked whether they would like to switch the the Debug Perspective as
they are when a Java application or Eclipse application (run time
workbench) suspends. How do I implement this?
Thanks in advance
Matt D.
| Re: Switching to debug perspective on suspend [message #313982 is a reply to message #313978] |
Thu, 29 March 2007 12:46   |
Originally posted by: mike.morearty.com
Probably your code is not broadcasting the right debug event. If you are
on Eclipse 3.2, take a look at LaunchSuspendTrigger.handleDebugEvents() --
that is the function that is listening for debug events, and switching to
the debug perspective when a suspend event comes in.
In that function, you can see that the conditions that must be true for it
to trigger are:
1. event.getKind() == DebugEvent.SUSPEND
2. event.isEvaluation() is false
3. event.getDetail() != DebugEvent.STEP_END
4. event.getSource() is an instance of IAdaptable, and can be adapted to
ILaunch
5. after adapting to ILaunch, the result must be equal to member variable
fLaunch. It isn't immediately obvious how that member variable is
initialized, but if you declare your IThread implementation to extend the
Eclipse helper class DebugElement, then I think you'll be in good shape:
class MyThread extends DebugElement implements IThread {
public MyThread(MyDebugTarget target) {
super(target);
By passing in an IDebugTarget to the DebugElement constructor,
DebugElement knows how to correctly create DebugEvents that point to the
right Launch. (You need to make sure your MyDebugTarget.getLaunch()
function returns the right value. One thing to be careful about: Even if
MyDebugTarget also extends DebugElement, you still need to have
MyDebugTarget override getLaunch(), because if you don't, you'll get into
an infinite loop, where the superclass DebugElement.getLaunch() calls
getDebugTarget().getLaunch().)
Once you do that, MyThread will inherit a public helper function
fireSuspendEvent(int detail), which will create a DebugEvent with the
correct values.
- Mike Morearty, Adobe Flex Builder
Matt Dickie wrote:
> Hi all,
> Thanks in advance
> Matt D.
| Re: Switching to debug perspective on suspend [message #313998 is a reply to message #313982] |
Fri, 30 March 2007 10:32  |
Thanks Mike,
The debug events were fired fine. The problem was that my thread class
didn't adapt to ILaunch. My debug element class didn't extends
DebugElement as that class is new in 3.1 and therefore not mentioned in
the debugger article - this provides some adapters for you. I have now
extended DebugElement and it works.
Matt D.
> are on Eclipse 3.2, take a look at
> LaunchSuspendTrigger.handleDebugEvents() -- that is the function that is
> listening for debug events, and switching to the debug perspective when
> it to trigger are:
> ILaunch
> variable fLaunch. It isn't immediately obvious how that member variable
> is initialized, but if you declare your IThread implementation to extend
> the Eclipse helper class DebugElement, then I think you'll be in good
> shape:
> super(target);
> if MyDebugTarget also extends DebugElement, you still need to have
> into an infinite loop, where the superclass DebugElement.getLaunch()
> calls getDebugTarget().getLaunch().)
> correct values.
> Matt Dickie wrote:
>> Hi all,
>> Thanks in advance
>> Matt D.
FUDForum. Page generated in 0.03735 seconds
