Home » Eclipse Projects » Eclipse Platform » lazystart and BundleActivator.start(BundleContext)
lazystart and BundleActivator.start(BundleContext) [message #313182] Tue, 06 March 2007 10:30 Go to next message
I'm wondering exactly how you're supposed to call the
BundleActivator.start(BundleContext) method manually.
This is my situation:
PluginA
- Eclipse-LazyStart: false
PluginB
- Eclipse-LazyStart: true
- Depends on PluginA
PluginB must set properties in PluginA in order for PluginA to start()
propertly. After I set the properties, how do I go about propertly calling
PluginAActivator.start(BundleContext)? What do I need to pass in for the
argument BundleContext?
Thanks in advance,
Albert
Re: lazystart and BundleActivator.start(BundleContext) [message #313761 is a reply to message #313182] Mon, 26 March 2007 09:35 Go to previous message
> PluginA
> PluginB
1) that's not a good dependancy tree, if B needs A, but A can't start
without information from B ... what about creating A, B, and Ba, where A
needs Ba which can set the preference.
2) you can manually start a plugin by looking up the Bundle (I use
Platform, although there's a better way in 3.3) and calling Bundle#start().
3) if you manually start a bundle, it will be auto-restarted the next
time eclipse starts back up ... you either have to be prepared for that
in plugin A (save the prop in your state location) or make sure you stop
it on the way out.
PW
Previous Topic:Using commands without eclipse.ui plugin.
Next Topic:Create a dynamic menu
Current Time: Mon Nov 10 10:46:58 EST 2025
Powered by FUDForum. Page generated in 0.04989 seconds
