| how to tell the difference between a file being deleted and a project being deleted? [message #313109] |
Thu, 01 March 2007 12:34  |
My problem might sound simple:
If a property file (an xml I use to store special data about the project) is
deleted I have to regenerate it.
If the whole project is deleted (the contents too) I must not regenerate the
property file (or else the deletion will stop with an error).
The problem is, that in my ResourceChangeListener in both cases I see the
following:
-The project is in CHANGED state.
-The findMember function of the project returns null for my property file.
I simply don't know how to tell the difference, can anyone help me?
Kristof
| Re: how to tell the difference between a file being deleted and a project being deleted? [message #313113 is a reply to message #313111] |
Thu, 01 March 2007 14:16   |
I'm sure.
I first receive a PRE_DELETE event telling me that the project is to be
deleted, from which I assume, that all of it's files will become unavailable
for me too (deleted or not).
After this comes the POST_CHANGE event I mentioned before.
Should I create some internal state machine, describing in what states the
projects are?
(The second event is separated from the first, I could also assume, that the
deletion failed, but some file remained, which is like a simple file
deletion "action").
Kristof
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:es744v$get$1@utils.eclipse.org...
> Kristof,
> I don't know much about this, but I believe the deltas form a tree so
> when a project is deleted, I think the deleted file delta will be a
> child of the deleted project delta and that this would be the way to
> tell. You're sure the project's delta isn't a REMOVED delta in the case
> of deleting a project? Perhaps the thing that creates the file should
> be a builder instead...
project) is
the
the
> > following:
file.
> > Kristof
| Re: how to tell the difference between a file being deleted and a project being deleted? [message #313115 is a reply to message #313113] |
Thu, 01 March 2007 15:30  |
Originally posted by: wharley.bea.com
"Kristof Szabados" <szabadosk@yahoo.com> wrote in message
news:es78qs$h3l$1@utils.eclipse.org...
> I'm sure.
> unavailable
> projects are?
> the
> deletion "action").
> Kristof
There's a nice article about resource listeners by John Arthorne, at
http://www.eclipse.org/articles/Article-Resource-deltas/reso urce-deltas.html.
I agree with Ed that you might want to consider using a builder rather than
a resource listener. A builder is a nice way to ensure that a certain file
gets built when it needs to, without getting into threading weirdness and
performance problems, and project deletion is not going to inadvertently
cause your builder to generate a file. Builders also avoid certain problems
with initialization that resource listeners are prone to - e.g., problems
with getting the listener registered in time to respond to events during
startup.
FUDForum. Page generated in 0.04787 seconds
