| Plugin - mark or color or evidence a row in text editor [message #1648057] |
Tue, 03 March 2015 13:56  |
Eclipse User  |
Hi everybody. I'm new to plugin development in eclipse, and I'm trying to achieve this task. I've done a popup menu with target ID="#TextEditorContext" (in plugin.xml) so it appear into the text editor when I press the right button of the mouse. Then my problem is evidencing a row. Here is the code of my Mark class that handles the context menu interactions.
package com.slicerplugin.popup.actions;
import java.awt.Color;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.IEditorActionDelegate;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IObjectActionDelegate;
import org.eclipse.ui.IViewActionDelegate;
import org.eclipse.ui.IViewPart;
import org.eclipse.ui.IWorkbenchPart;
public class Mark implements IEditorActionDelegate  {
	private Shell shell;
	 * Constructor for Action1.
	public Mark() {
		super();
	 * @see IObjectActionDelegate#setActivePart(IAction, IWorkbenchPart)
	public void setActivePart(IAction action, IWorkbenchPart targetPart) {
		shell = targetPart.getSite().getShell();
	 * @see IActionDelegate#run(IAction)
	public void run(IAction action) {
		MessageDialog.openInformation(
			shell,
			action.getActionDefinitionId(),
			action.getAccelerator()+" ");
	 * @see IActionDelegate#selectionChanged(IAction, ISelection)
	public void selectionChanged(IAction action, ISelection selection) {
				shell,
				selection.toString());
	public void setActiveEditor(IAction action, IEditorPart targetEditor) {
		// TODO Auto-generated method stub
				shell,
				targetEditor.getTitle());
The code is actually pseudo random just for explore something.
Someone have idea of how can I achieve this task?????????????
Thanks thousand!
FUDForum. Page generated in 0.04556 seconds
