Home » Archived » Jubula » Read a timewatch
Read a timewatch [message #1645674] Mon, 02 March 2015 11:31 Go to next message
Hi guys,
I'm a beginner with jubula and I test an application that compiles genetics maps ... I want to calculate how much milliseconds do the loading of the maps takes ... I used the startTimer and readTimer fonctions but my problem is how to read or exactly how to get ("printable" if I can say) the value of the variables where the times were stored?
Re: Read a timewatch [message #1647765 is a reply to message #1645674] Tue, 03 March 2015 10:50 Go to previous messageGo to next message
Hi there,
you'll need to use the actions: start timer, read timer and then check numeric values. The start timer starts a timer with a variable that you define. Then you use read timer to store the value of the timer (which saves the difference (in milliseconds) between the current time and the time at which the timer was started). Then you use this variable in the check numeric values action to compare it with a value you expect.
The docs for these actions are here:
http://help.eclipse.org/luna/topic/org.eclipse.jubula.client.ua.help/html/reference/node12.html?cp=35_3_1_0
(search for "start timer", "read timer" and "check numeric values").
If you're unsure about how variables work, check out the documentation on them:
http://help.eclipse.org/luna/topic/org.eclipse.jubula.client.ua.help/html/manual/node151.html
Alex
Re: Read a timewatch [message #1647786 is a reply to message #1647765] Tue, 03 March 2015 11:03 Go to previous message
Hi Alex,
Thanks for the detailed replay and in such a short time XD.
Lydia
Previous Topic:stopwatch function !
Next Topic:How to Read String,Values from Table
Current Time: Mon Nov 03 15:32:02 EST 2025
Powered by FUDForum. Page generated in 0.03986 seconds
