Home » Eclipse Projects » Eclipse Platform » [DataBinding] RegexStringValidator removed
[DataBinding] RegexStringValidator removed [message #310840] Mon, 18 December 2006 19:02 Go to next message
I see that from HEAD RegexStringValidator has been removed.
Is there any plan for a workaround? CVS log is
"Fix for Bug 128142 [DataBinding] IDomainValidator needs to provide
partial validation / be merged with IValidator"
But I do not see a connection with the bug. Is this a refactoring or is
it thought that RegexStringValidator did not fit along with the other
standard validators? Should *we* implement this validator?
Hasan Ceylan
Re: [DataBinding] RegexStringValidator removed [message #310973 is a reply to message #310840] Fri, 22 December 2006 15:03 Go to previous messageGo to next message
Originally posted by: bokowski.ca.ibm.com
It is very easy for clients to implement a validator based on
Pattern.matches. I removed it because java.util.regex is not available in
the Foundation 1.0 class libraries (subset of J2SE 1.3) that we are
targeting as the execution environment.
"Hasan Ceylan" <hceylan@ytg.com.tr> wrote in message
news:em7a65$bec$1@utils.eclipse.org...
> But I do not see a connection with the bug. Is this a refactoring or is it
> Hasan Ceylan
Re: [DataBinding] RegexStringValidator removed [message #310987 is a reply to message #310973] Sat, 23 December 2006 08:12 Go to previous message
Thanks Boris...
Previous Topic:Web application interacting with Eclipse Plugin
Next Topic:Adding actions to an Image
Current Time: Tue Nov 04 20:52:12 EST 2025
Powered by FUDForum. Page generated in 0.05448 seconds
