Home » Eclipse Projects » Eclipse Platform » problem to start Infocenter in 3.2.0
problem to start Infocenter in 3.2.0 [message #310125] Wed, 22 November 2006 07:03
I am trying to start 'Infocenter' from command line:
java -classpath
/app/eclipse/3.2/plugins/org.eclipse.help.base_3.2.0.v200606 01.jar
org.eclipse.help.standalone.Infocenter -command start -port 6969
-eclipsehome /app/eclipse/3.2 -noexec -data
/home/eraonel/linux_RBSSW_WENDY_RBS_INC3.32_DEV -host ws3735
Help web application could not start. Check the log file at
/home/eraonel/linux_RBSSW_WENDY_RBS_INC3.32_DEV/.metadata/.l og for details.
This is the log file:
ENTRY org.eclipse.help.base 4 0 2006-11-22 12:53:02.937
!MESSAGE Stand-alone help control web application failed to run.
!STACK 1
org.eclipse.core.runtime.CoreException: Exception occurred starting
application server.
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:271)
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:143)
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:41)
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:58)
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSystem.java:234)
org.eclipse.help.internal.base.HelpApplication.run(HelpAppli cation.java:62)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!SUBENTRY 1 org.eclipse.tomcat 4 0 2006-11-22 12:53:02.937
!MESSAGE Exception occurred starting application server.
Any ideas what is going wrong?
cheers,
//mikael
Previous Topic:how to determine wheter a certain editor is available?
Next Topic:Plug-in cache
Current Time: Sun Nov 09 20:37:26 EST 2025
Powered by FUDForum. Page generated in 0.03017 seconds
