| Doubt about chosing Particiapnt while extending Team Sychronize [message #309605] |
Thu, 02 November 2006 06:35  |
Originally posted by: priya_kothari.persistent.co.in
I am writing a plugin for a SCM. I want to extend the Team Synchronization
behavior. I have written a participant which extends SubscriberParticipant.
But there is another class viz ModelSynchronizeParticipant. I don't
understand the behavioral difference in these two particpants. Can some one
tell me the advantages / disadvantages of both?
Also when I do synchronize for my plugin, and click on finish, it pop-ups a
dialog of whether I want to switch to Team Synchronization Perspective. But
I don't want this dialog box to come up and on Finish its should directly
open my custom perspective. How I can achieve this?
TIA
~Priya
| Re: Doubt about chosing Particiapnt while extending Team Sychronize [message #309653 is a reply to message #309643] |
Fri, 03 November 2006 08:21  |
Priya,
I'm not sure what you mean. For CVS synchronizations, the Team
preference is used. The perspective switch is performed in the
ISynchronizeManager#showSynchronizeViewInactivePage() method. There is
no way to override this programmatically. CVS has its own perspective
switching for the Show Annotate operation but that is independent of
synchronizing.
Michael
Priya wrote:
> Thanks for the info. I had one more doubt about the dialog box for Team
> Perspective. Is there any way I can programmatically through my plugin set
> the perspective to be opened on Synchronize action?
> The same way as CVS does, CVS plugin does not change the perspective in the
> Team preference page. I guess it does it programmatically using
> getPreferenceStore.
> Any pointers would be of great help.
> TIA
> ~Priya
> "Michael Valenta" <Michael_Valenta@ca.ibm.com> wrote in message
> news:eicsn1$d6t$1@utils.eclipse.org...
>> Priya wrote:
>>> Hi,
>>> Synchronization behavior. I have written a participant which extends
>>> SubscriberParticipant. But there is another class viz
>>> ModelSynchronizeParticipant. I don't understand the behavioral difference
>>> in these two particpants. Can some one tell me the advantages /
>> ModelSynchronizeParticipants allow model providers to participate in the
>> rendering of the tree in the sync view. For example, if a synchronization
>> contained Java projects, the projects would appear as java projects in the
>> synchronize view and would contain packages instead of folders. Here's a
>> link to the doc that describes this API. Have a look at the repository
>> roadmap.
>> http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/team_model.htm
>>> a dialog of whether I want to switch to Team Synchronization Perspective.
>>> But I don't want this dialog box to come up and on Finish its should
>>> directly open my custom perspective. How I can achieve this?
>> This is controlled by a preference on the Team preference page. You can
>> configure whether you should be prompted and what perspective to switch
>> to.
>>> TIA
>>> ~Priya
FUDForum. Page generated in 0.03918 seconds
