Re: Namespace reporting is not enabled [message #3120 is a reply to message #3095] |
Mon, 25 August 2008 11:22 |
barak Messages: 5 Registered: July 2009 |
Thanks for helping, and sorry for the typos in the previous post...
So, I download the standelone Eclipse Memory Analyzer from
www.eclipse.org. I'm running Windows XP, professional edition, Java
version is:
java version "1.6.0_02"
Java(TM) SE Runtime Environment (build 1.6.0_02-b06)
Java HotSpot(TM) Client VM (build 1.6.0_02-b06, mixed mode).
The dump was created on linux box (Centos5, same jdk), using jmap.
Here is the stack:
eclipse.buildId=unknown
java.version=1.6.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=iw_IL
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Mon Aug 25 14:12:14 IDT 2008
java.io.IOException: Parser configuration problem: namespace reporting is
not enabled
The other 2 frames in the stack (somehow I cant copy them) show exactly
the same: Parser configuration problem: namespace reporting is not enabled.
Thanks for any help, I'll try to open the bug soon.
Barak.
FUDForum. Page generated in 0.03641 seconds
