Home » Archived » M2M (model-to-model transformation) » [ATL] Transformation only executes once
[ATL] Transformation only executes once [message #31122] Fri, 13 April 2007 06:22 Go to next message
Originally posted by: strommer.big.tuwien.ac.at
hi!
I'm having a problem concerning the execution of an ATL transformation.
The thing is that I can only execute the transformation once every time
I start eclipse. If I try to launch it a second time I get a
"message: cannot find model Map1"
.. My launch configuration includes one metamodel that is referenced by
URI and is actually a custom extension to Ecore. I remember some
problems with locked resources but in my case I can't understand why
this should happen. If I use any other metamodel by URI but mine
everything works fine.
Does anyone know how to deal with this ATL behavior?
Michael
Re: [ATL] Transformation only executes once [message #31722 is a reply to message #31122] Sat, 14 April 2007 12:30 Go to previous messageGo to next message
How do you register your metamodel?
As a plugin, or using the "Register metamodel" action?
Frédéric Jouault
Michael Strommer wrote:
> hi!
> Cheers,
> Michael
Re: [ATL] Transformation only executes once [message #31861 is a reply to message #31722] Mon, 16 April 2007 06:27 Go to previous messageGo to next message
hi!
I just register the metamodel with the generated EMF plugin.
Michael
Frédéric Jouault schrieb:
> Hello,
> Frédéric Jouault
>> hi!
>> transformation. The thing is that I can only execute the
>> transformation once every time I start eclipse. If I try to launch it
>> by URI and is actually a custom extension to Ecore. I remember some
>> Cheers,
>> Michael
Re: [ATL] Transformation only executes once [message #31969 is a reply to message #31861] Mon, 16 April 2007 10:50 Go to previous messageGo to next message
Could you please try to load your Ecore metamodel instead of using the
registered version? This may help us diagnose the problem.
Frédéric Jouault
> hi!
> Best regards,
> Michael
>> Hello,
>> Regards,
>> Frédéric Jouault
>>> hi!
>>> Cheers,
>>> Michael
Re: [ATL] Transformation only executes once [message #32004 is a reply to message #31969] Mon, 16 April 2007 11:46 Go to previous messageGo to next message
hi!
Loading the ecore model was my first approach. I got the following warnings:
Warning: metamodel contains several classifiers with same name: EAttribute
ecore::EAttribute
Warning: metamodel contains several classifiers with same name: EAnnotation
ecore::EAnnotation
Warning: metamodel contains several classifiers with same name: EClass
ecore::EClass
Our metamodel is designed as an extension to Ecore that allows us to
have mappings between EClasses, EAttributes, etc. So we loaded the Ecore
metamodel as resource into the Ecore editor to use Ecore classes as
super classes in our mapping metamodel. The generated EMF plugins worked
fine, also did the GMF editor based on these plugins.
I just downloaded the latest ATL and AM3 versions from cvs and tried the
"register metamodel" funtionality but this made ATL not work in the
first run.
Thx for the help,
Michael
> Hello,
> Frédéric Jouault
>> hi!
>> Best regards,
>> Michael
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>>> hi!
>>>> Cheers,
>>>> Michael
Re: [ATL] Transformation only executes once [message #32039 is a reply to message #32004] Mon, 16 April 2007 12:21 Go to previous messageGo to next message
Well, if you extend Ecore, then is your metamodel actually a
metametamodel? In this case, you might need to do some modifications to
EMF to use your metametamodel in place of Ecore.
Do you refer to Ecore elements or did you copy them in your
(meta)metamodel? It is a bit strange that the EMF driver finds several
classes named EAttribute, for instance.
I am not sure what you mean by "mappings between EClasses, EAttributes,
etc." but it sounds like model weaving would be a much simpler approach
to me.
Frédéric Jouault
> hi!
> warnings:
> ecore::EAttribute
> ecore::EAnnotation
> ecore::EClass
> first run.
> Thx for the help,
> Michael
>> Hello,
>> Regards,
>> Frédéric Jouault
>>> hi!
>>> Best regards,
>>> Michael
>>>> Hello,
>>>> Regards,
>>>> Frédéric Jouault
>>>>> hi!
>>>>> referenced by URI and is actually a custom extension to Ecore. I
>>>>> remember some problems with locked resources but in my case I can't
>>>>> understand why this should happen. If I use any other metamodel by
>>>>> URI but mine everything works fine.
>>>>> Cheers,
>>>>> Michael
Re: [ATL] Transformation only executes once [message #32320 is a reply to message #32039] Tue, 17 April 2007 04:37 Go to previous message
you are right, it is a metametamodel. in our mapping extension to Ecore
we reference all Ecore elements and did not copy them. (The EMF code
generator provides a feature to reference existing genmodels)
We do model weaving, but we would like to have a graphical editor and
our own mapping language. That's why we do not use the model weaver or a
weaving metamodel extension.
I will try to debug the ATL source to find out why the transformation
works only once.
Michael
> to me.
> Frédéric Jouault
>> hi!
>> warnings:
>> EAttribute
>> ecore::EAttribute
>> EAnnotation
>> ecore::EAnnotation
>> ecore::EClass
>> Ecore metamodel as resource into the Ecore editor to use Ecore
>> classes as super classes in our mapping metamodel. The generated EMF
>> plugins worked fine, also did the GMF editor based on these plugins.
>> the "register metamodel" funtionality but this made ATL not work in
>> the first run.
>> Thx for the help,
>> Michael
>>> Hello,
>>> the registered version? This may help us diagnose the problem.
>>> Regards,
>>> Frédéric Jouault
>>>> hi!
>>>> Best regards,
>>>> Michael
>>>>> Hello,
>>>>> Regards,
>>>>> Frédéric Jouault
>>>>>> hi!
>>>>>> can't understand why this should happen. If I use any other
>>>>>> metamodel by URI but mine everything works fine.
>>>>>> Cheers,
>>>>>> Michael
Previous Topic:[ATL] EBNF Injection warnings - with MDR
Next Topic:CPL2SPL sample does not work with ATL_bundle eclipse
Current Time: Mon Oct 27 16:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.05399 seconds
