Home » Eclipse Projects » NatTable » Copy the text from Non Editable Cell(Copy the text from Non Editable Cell)
Copy the text from Non Editable Cell [message #1632587] Tue, 24 February 2015 06:06 Go to next message
I need the following functionality in my nattable implementation
Copy the text from Non Editable Cell of Nat Table
Can you please suggest, how to achieve it ?
Ambuj
Re: Copy the text from Non Editable Cell [message #1632708 is a reply to message #1632587] Tue, 24 February 2015 07:37 Go to previous messageGo to next message
Hi Ambuj ,
Do you mean programmatically or by user action?
Take a look at org.eclipse.nebula.widgets.nattable.copy.action.CopyDataAction:
natTable.doCommand(new CopyDataToClipboardCommand("\t", System.getProperty("line.separator"), natTable.getConfigRegistry()));
You can create a menu item with this code for user request copy.
Hope it helps,
Arye
Re: Copy the text from Non Editable Cell [message #1637131 is a reply to message #1632708] Thu, 26 February 2015 10:01 Go to previous messageGo to next message
Thanks for the reply. I need to know, if there are any sample code which copies the text from non editable cell
Ambuj
Re: Copy the text from Non Editable Cell [message #1637139 is a reply to message #1637131] Thu, 26 February 2015 10:09 Go to previous messageGo to next message
Hi Ambuj,
Can you describe the problem better? What is the scenario? What inputs do you have?
Re: Copy the text from Non Editable Cell [message #1637151 is a reply to message #1637139] Thu, 26 February 2015 10:15 Go to previous messageGo to next message
NatTable Examples Application -> Tutorial Examples -> Additional Functions -> CopyExample
Re: Copy the text from Non Editable Cell [message #1644803 is a reply to message #1637139] Mon, 02 March 2015 02:15 Go to previous messageGo to next message
Thank you
The solution worked for me.
Ambuj
Re: Copy the text from Non Editable Cell [message #1644806 is a reply to message #1632708] Mon, 02 March 2015 02:16 Go to previous message
Arye Shemesh wrote on Tue, 24 February 2015 07:37
Hi Ambuj ,
Hope it helps,
Arye
Thanks Arye...it worked
Previous Topic:Creating structure in Tree
Next Topic:Nattable Tree Structure
Current Time: Tue Jul 08 05:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.06090 seconds
