Home » Modeling » Epsilon » [ETL] How to create a target model by java code
[ETL] How to create a target model by java code [message #1625488] Fri, 20 February 2015 07:17 Go to next message
Hi to everybody,
i have been using Epsilon ecosystem for a few time
I have read many post in this forum but i have not found anything to help me.
I need to call from java code an etl transformation.
Before, I used the tree2graph.etl file from example by ant script and the transformation succeeded to create a target file, now i would like to reach the same result from java code.
I have seen the example for eunit and i have caught the code to create an empty model
protected EmfModel loadEmptyModel(String name, String metamodelPath)	throws EolModelLoadingException
 EmfModel model = new EmfModel();
 model.setName(name);
 model.setMetamodelFileUri(getResourceEmfURI(metamodelPath));
 model.setModelFileUri(URI.createFileURI(new File("Empty" + name + ".model").getAbsolutePath()));
 model.setReadOnLoad(false);
 model.setStoredOnDisposal(false);
 model.load();
 return model;
but i can not create a file for this target model after the correct execution of the transformation.
If i create the file from
File file = new File(path);
file.createNewFile();
the file is created in the target folder but it remains empty.
thanks in advance
Re: [ETL] How to create a target model by java code [message #1625495 is a reply to message #1625488] Fri, 20 February 2015 07:21 Go to previous messageGo to next message
Hi Daniele,
Could you please put together a minimal example [1] that demonstrates the issue you're encountering?
Dimitris
[1] http://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Re: [ETL] How to create a target model by java code [message #1625615 is a reply to message #1625488] Fri, 20 February 2015 09:14 Go to previous messageGo to next message
here [1] there is the minimal example of my project.
I have used your code for EtlStandaloneExample to understand how epsilon work with the transformation and the models/metamodels.
After launching the transformation the simple program does nothing, instead in the example with ant (tree2Graph) the transformation creates the target model at the end of transformation.
greetings
Daniele
Re: [ETL] How to create a target model by java code [message #1625632 is a reply to message #1625615] Fri, 20 February 2015 09:29 Go to previous messageGo to next message
Hi Daniele,
In your loadEmptyModel method you'll need to replace
with
model.setStoredOnDisposal(true);
Dimitris
Re: [ETL] How to create a target model by java code [message #1625689 is a reply to message #1625632] Fri, 20 February 2015 10:16 Go to previous messageGo to next message
Hi Daniele,
On a related note, you don't need both epsilon-...-kitchensink.jar and o.e.e.eol.engine.jar in the classpath. The former should suffice.
Dimitris
Re: [ETL] How to create a target model by java code [message #1625800 is a reply to message #1625689] Fri, 20 February 2015 11:53 Go to previous message
Thanks dimitris,
now it works fine.
greetings
Daniele
Previous Topic:Assign existing Papyrus model and diagram to a ETL target model and diagram
Next Topic:new icons in Exeed
Current Time: Fri Nov 07 08:02:39 EST 2025
Powered by FUDForum. Page generated in 0.03471 seconds
