Home » Eclipse Projects » Eclipse Platform » welcom page
welcom page [message #306496] Mon, 31 July 2006 13:36 Go to next message
What is the best way to implement a welcome page? Is the welcom.xml
supported on Eclipse 3.1? I have tried that and it didn't seems to work.
Is the "org.eclipse.ui.intro" the right thing to use if I am devlopement a
new plguin for eclipse that will consist of a welcom screen?
Carl
Re: welcom page [message #306551 is a reply to message #306496] Tue, 01 August 2006 16:10 Go to previous message
Originally posted by: duncan.krebsnet.com
The easiest way to get started is to create a new plugin, in the wizard
select the option to create RCP application, and then on the next page in
the wizard use the template that contains an intro.
In general, to create an intro you need to use 2 extension points. First
org.eclipse.ui.intro and then org.eclipse.ui.introConfig, the generated
plugin gives a good example.
Previous Topic:How do you upgrade from V3.1.2 to V3.2?
Next Topic:How should a plugin check JDK version
Current Time: Sat Nov 08 06:12:21 EST 2025
Powered by FUDForum. Page generated in 0.03764 seconds
