Home » Language IDEs » ServerTools (WTP) » IBM contribution - plugs don't show in Eclipse
IBM contribution - plugs don't show in Eclipse [message #30802] Sat, 24 July 2004 13:40 Go to next message
Originally posted by: mike.home.net
Having installed everything as per the "Getting Started" guide, Eclipse
doesn't pick up on the presence of the newly installed plugins. E.g. Under
Window->Show view->Other there is no entry for "Data".
Any ideas what I may be doing wrong?
M
Re: IBM contribution - plugs don't show in Eclipse [message #31079 is a reply to message #30802] Sun, 25 July 2004 05:58 Go to previous messageGo to next message
Originally posted by: rui.figueira.vilt.com.pt
I had the same problem. Then I installed VE and now everything seems to
work fine.
Mike wrote:
> M
Re: IBM contribution - plugs don't show in Eclipse [message #31183 is a reply to message #31079] Sun, 25 July 2004 14:14 Go to previous messageGo to next message
That doesn't seem to help - I already had VE installed anyway, as it's in
the list on the "Getting Started" page.
Mike
"Rui Figueira" <rui.figueira@vilt.com.pt> wrote in message
news:ce008v$frh$1@eclipse.org...
> work fine.
> Mike wrote:
> > Hi,
Under
> > Thanks,
> > M
Re: IBM contribution - plugs don't show in Eclipse [message #31399 is a reply to message #31183] Sun, 25 July 2004 23:41 Go to previous messageGo to next message
Originally posted by: engebret.mchsi.com
I had the same problem initially too. What I ended up doing was just
downloading a fresh install of
eclipse and then installing the ibm.zip files and the other required
eclipse libraries (GEF, VE, etc). After
that I was able to use the new ibm options. My current theory is that I
had other plugins in my old
eclipse install that might have conflicted, not sure if that is possible
but you never know :0)
> Mike
> > Hi,
> > work fine.
> > Mike wrote:
> > > Hi,
> Under
> > > Thanks,
> > > M
Re: IBM contribution - plugs don't show in Eclipse [message #35120 is a reply to message #31079] Fri, 30 July 2004 09:27 Go to previous messageGo to next message
Finally had success.
Under Help - Software Updates - Manage Configuration, I selected the "Show
Disabled Features" button in the toolbar. The IBM package showed up and I
could enable it.
Mike
> work fine.
> Mike wrote:
> > Hi,
Under
> > Thanks,
> > M
Re: IBM contribution - plugs don't show in Eclipse [message #41219 is a reply to message #30802] Wed, 01 September 2004 15:41 Go to previous message
Maybe you made the same mistake I did and neglected to unzip the
com.ibm.wtp.sdk*.zip file. The documentation
( http://www.eclipse.org/webtools/initial-contribution/IBM/Get ting%20Started.html)
actually tells you to do this ("download the ibm.zip and extract
it. It contains an a copy of this "Getting Started" guide and the
com.ibm.wtp.sdk zip file. Unzip this SDK into the same location as the
above SDKs") but it's pretty easy to overlook.
Larry Mulcahy Please address email to lmulcahy@qmail.qwest.net
PGP public key at: Good system software should be free, like air
http://pgpkeys.mit.edu:11371/pks/lookup?op=get&search=0x 2C4C5A03
Previous Topic:Long running "Building workspace"
Next Topic:Run menu doesn't contain Web Services Explorer
Current Time: Tue Aug 19 17:14:34 EDT 2025
Powered by FUDForum. Page generated in 0.04499 seconds
