ContactManager loading contacts from a database [message #512039] |
Wed, 03 February 2010 17:35 |
Andy Maleh Messages: 28 Registered: July 2009 |
hadenp said:
Glimmer looks fantastic! As a first try I'm modifying Contact Manager, to load @contacts[] from a database(activerecord-jdbcsqlite3-adapter). When I run it (Jruby -w) I get...
"Processing method: text and args: ["Contact Manager"]
java.lang.ClassNotFoundException: org.eclipse.swt.Table"
Is this a name conflict with another Table and if so how can I resolve it?
Thanks!
Haden
Andy said:
No, this is pretty much the SWT table used in the Contact Manager application. This error happens if you do not have SWT installed correctly. Refer to the README file for instructions on how to install SWT if you have not already.
Did you run the program successfully before modifying Contact Manager to load a database? Make sure it runs fine in its original form first.
If you encounter an error again, please post a stack trace (or the top 10 entries at least)?
hadenp said:
Here's the modified Contact_Repository (excerpt) and below it the error I get(w/o -w flag). Hope I'm not bothering you with something obvious that I'm doing wrong...
require 'rubygems'
require 'active_record'
gem 'activerecord-jdbcsqlite3-adapter'
require 'yaml'
require File.dirname(__FILE__) + "/contact"
class ContactRepository
def initialize
@connections = YAML.load_file("database.yml")
ActiveRecord::Base.establish_connection(@connections["development "])
stmt = "select first_name, last_name, email from contacts"
@val = ActiveRecord::Base.connection.select_all(stmt)
@contacts = []
@val.each do |c|
#puts "@val= #{c["first_name"]} #{c["last_name"]} #{c["email"]}"
@map = {:first_name => c["first_name"], :last_name => c["last_name"], :email => c["email"] }
#puts "@map= #{@map}"
@contacts << Contact.new( @map )
end
# @contacts = [
# Contact.new(:first_name => "Anne", :last_name => "Sweeney", :email => "anne@sweeny.com"),
# Contact.new(:first_name => "Beatrice", :last_name => "Jung", :email => "beatrice@jung.com"),
# Contact.new(:first_name => "Frank", :last_name => "Deelio", :email => "frank@deelio.com"),
# Contact.new(:first_name => "franky", :last_name => "miller", :email => "frank@miller.com"),
end
Here's the error...
C:\gui\samples\contactmanager>jruby contact_manager.rb
c:/jruby/lib/ruby/gems/1.8/gems/facets-2.8.1/lib/core/facets /kernel/here.rb:9 warning: `binding' should not be aliased
Loading command handlers for DSL: swt
@val= Fred Apple fredapple@ma.com
@map= first_nameFredlast_nameAppleemailfredapple@ma.com
@val= Joe Napolitano joeynap@yahoo.com
@map= first_nameJoelast_nameNapolitanoemailjoeynap@yahoo.com
@val= Alice Laring alice.laring@gmail.com
@map= first_nameAlicelast_nameLaringemailalice.laring@gmail.com
Processing method: shell and args: []
ShellCommandHandler will handle command: shell with arguments []
c:/jruby/lib/ruby/gems/1.8/gems/activesupport-2.3.5/lib/acti ve_support/core_ext/string/output_safety.rb:25:in `add_with_
safety': can't convert nil into String (TypeError)
from ./../../src/command_handlers/models/r_widget.rb:55:in `respond_to?'
from ./../../src/command_handlers/widget_method_command_handler.r b:19:in `can_handle?'
from ./../../src/command_handler_chain_link.rb:20:in `handle'
from ./../../src/command_handler_chain_link.rb:24:in `handle'
from ./../../src/glimmer.rb:29:in `method_missing'
from ./../../src/glimmer.rb:41:in `method_missing'
from contact_manager.rb:29
from ./../../src/command_handlers/models/r_widget.rb:144:in `call'
from ./../../src/command_handlers/models/r_widget.rb:144:in `process_block'
from ./../../src/glimmer.rb:36:in `add_contents'
from ./../../src/glimmer.rb:30:in `method_missing'
from contact_manager.rb:28
FUDForum. Page generated in 0.02612 seconds
