Home » Archived » BIRT » How to get all Label controls using Designer API?
How to get all Label controls using Designer API? [message #999296] Fri, 11 January 2013 13:53 Go to next message
We need to analyze all label controls used in report design... Looks like Designer API is what we need but we are just a bit confused on how to search recursively through design object like DesignElementHandle, SlotHandle, DesignElement...etc. Not really sure how these objects relate to each other and how to extract one from another...May be, the board experts (Michael, Jason?) could quickly to point to an example that does something like that?
Alexey
Re: How to get all Label controls using Designer API? [message #1000907 is a reply to message #999296] Tue, 15 January 2013 12:00 Go to previous messageGo to next message
Sorry for the delay. So, you want to be able to grab the values of all of the labels in a report design? Are the reports designed dynamically? Are there any dynamically created labels? Or are they all statically created? Will you use these values within the design? Can you explain a little bit more?
Re: How to get all Label controls using Designer API? [message #1001388 is a reply to message #1000907] Wed, 16 January 2013 11:01 Go to previous messageGo to next message
Michael,
Thanks anyway but I found an example provided by Jason W. on BIRT wiki.
Aleksey
Re: How to get all Label controls using Designer API? [message #1004181 is a reply to message #1001388] Tue, 22 January 2013 13:44 Go to previous message
Good to hear! Can you post the link to the example, in case someone stumbles across this thread looking for the same? Thanks!
Previous Topic:Problem in passing query string parameters from HTML to beforeOpen method of BIRT
Next Topic:securing BIRT url
Current Time: Sat Jul 26 11:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.18045 seconds
