Home » Archived » BIRT » Publishing/Sharing BIRT Reports
Publishing/Sharing BIRT Reports [message #999200] Fri, 11 January 2013 09:52 Go to next message
I'm new to BIRT and I've gotten the BIRT Report Designer setup. However, I'm not sure about what is the best practice for deploying my BIRT reports to the server with the BIRT runtime.
Is there a built-in BIRT deployment mechanism in the Report Designer? Or should I write a jsp page to upload the .rptdesign file to my server?
Thanks.
Re: Publishing/Sharing BIRT Reports [message #1000927 is a reply to message #999200] Tue, 15 January 2013 12:45 Go to previous message
No, unfortunately, there is no deployment mechanism to deploy your reports to Tomcat or whatever app server you're using, from the designer. In Actuate BIRT, this connection can be made to allow publishing to the BIRT iServer.
Previous Topic:specify alternate JDBC drivers folder
Next Topic:Charts in a crosstab column
Current Time: Fri Jul 25 04:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.06734 seconds
