Adding Xtext nature to Xtext project from existing ecore [message #999111] |
Fri, 11 January 2013 06:12  |
Hi everyone,
I've created new Xtext project from my ecore model. After some problems I've generated correctly Xtext Artifacts. Now, as usual, I've launched an Eclipse instance and I've created a new project. But when I create a new file with my extension will not appear dialog for adding Xtext nature to the project.
Why is this happening?
Re: Adding Xtext nature to Xtext project from existing ecore [message #999173 is a reply to message #999171] |
Fri, 11 January 2013 09:09   |
Plugin e plugin_gen in ui project are identical.
Console says:
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri 'E:\Workspaces\PrototipoAts'
511 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.sequenceruntime.AtsSequenceRuntimePackage'
511 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.atsvariable.AtsvariablePackage'
511 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.typesystem.AtstypesystemPackage'
512 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.sequenceedit.AtssequenceeditPackage'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/sequenceruntime' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceRuntime.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/sequenceedit' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/typesystem' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/variable' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://configuration' from 'platform:/resource/com.egicon.ats.devices.model/model/configuration.genmodel'
1161 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning E:\Workspaces\PrototipoAts\it.rcpvision.ats.suitetest.corelanguage\..\it.rcpvision.ats.suitetest.corelanguage\src-gen
1169 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning E:\Workspaces\PrototipoAts\it.rcpvision.ats.suitetest.corelanguage\..\it.rcpvision.ats.suitetest.corelanguage.ui\src-gen
1293 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for it.rcpvision.ats.suitetest.CoreLanguage with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, Ecore2XtextValueConverterServiceFragment, JavaValidatorFragment, ImportURIScopingFragment, SimpleNamesFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, CompareFragment, BuilderIntegrationFragment, QuickfixProviderFragment
3566 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
4520 [main] INFO text.generator.junit.Junit4Fragment - generating Compare Framework infrastructure
4607 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
FUDForum. Page generated in 0.06251 seconds
