Home » Modeling » EMF » [GWT] Where to download the runtime components
[GWT] Where to download the runtime components [message #998693] Thu, 10 January 2013 09:15 Go to next message
from further posts I have learned that I can't simply install the
EMF/GWT jars into my instance of Eclipse but have to create a directory
acting as a platform target.
So where can I download the required runtoime components.
I found
http://download.eclipse.org/modeling/emf/emf/updates/2.8/
but that just tells me it is an update site.
I'm using the latest Eclipse 4.2.1 with GWT 2.5.
Dirk
Re: [GWT] Where to download the runtime components [message #998713 is a reply to message #998693] Thu, 10 January 2013 09:42 Go to previous messageGo to next message
Seems I have found it myself as
http://www.eclipse.org/downloads/download.php?file=/modeling/emf/emf/downloads/drops/2.8.1/R201209170436/emf-xsd-Update-2.8.1.zip
Am 10.01.2013 15:15, schrieb Dirk Hoffmann:
> I found
> Regards,
> Dirk
Re: [GWT] Where to download the runtime components [message #998714 is a reply to message #998693] Thu, 10 January 2013 09:44 Go to previous messageGo to next message
Dirk,
Yes, they're in that update site. You need to use this URL and
provision a target platform as described in the wiki.
On 10/01/2013 3:15 PM, Dirk Hoffmann wrote:
> directory acting as a platform target.
> I found
> Regards,
> Dirk
Re: [GWT] Where to download the runtime components [message #998715 is a reply to message #998713] Thu, 10 January 2013 09:46 Go to previous messageGo to next message
Dirk,
It's easier to just use the URL...
>> Hi,
>> I found
>> Regards,
>> Dirk
Re: [GWT] Where to download the runtime components [message #998745 is a reply to message #998714] Thu, 10 January 2013 10:54 Go to previous messageGo to next message
Now to the newsgroup:
I managed to download it as a zip File, but still there are lines in the
generated code flagged red. For now these are imports of classes in
packages whose names start with
org.eclipse.emf.common
I would expect them in the
org.eclipse.emf.gwt.ecore.source_2.8.1.v20120917-0436.jar
but seemingly they arent not there.
But now I'm a bit lost.
My plans are to have the GWT client request data from the server as an
XML-serialized object of a type defined in Ecore.
How would I go about that? Are there the same concepts of
XMIResourceSets in the GWT area as in common Java?
Can I use the same Ecore model for the server as well as for the client?
See also below...
Thanks and Regards,
Dirk
Am 10.01.2013 15:44, schrieb Ed Merks:
> Dirk,
Which URL and which wiki do you mean?
>> Hi,
>> I found
>> Regards,
>> Dirk
Re: [GWT] Where to download the runtime components [message #998746 is a reply to message #998714] Thu, 10 January 2013 10:54 Go to previous messageGo to next message
> Dirk,
Which wiki and where. For me Eclipse is a huge universe and I often find
it hard to find the right galaxy.
Tried to run
../eclipsec.exe \
-application org.eclipse.equinox.p2.director \
-repository http://download.eclipse.org/modeling/emf/emf/updates/2.8 \
-installIU org.eclipse.emf.feature.group \
-tag FetchEMF \
-destination d:/s/K/emf2.8 \
-profile SDKProfile
but that failed.
Also appending /site.xml to the URL dis not succeed.
>> Hi,
>> I found
>> Regards,
>> Dirk
Re: [GWT] Where to download the runtime components [message #998775 is a reply to message #998746] Thu, 10 January 2013 12:16 Go to previous messageGo to next message
Dirk,
You don't want (can't have) the GWT runtime installed in the IDE. You
must create GWT target platform that contains them and you create such a
thing following the steps in http://wiki.eclipse.org/EMF/GWT
>> Dirk,
> find it hard to find the right galaxy.
> Tried to run
> ./eclipsec.exe \
> -tag FetchEMF \
> -profile SDKProfile
> but that failed.
>>> Hi,
>>> I found
>>> Regards,
>>> Dirk
Re: [GWT] Where to download the runtime components [message #999052 is a reply to message #998775] Fri, 11 January 2013 03:25 Go to previous messageGo to next message
Hi Ed,
thanks. I had been missing the fact that the IDE allows me to include
update sites into platform target definitions.
Still there is a problem: The "Edit Target Definition" dialog now
complains about an unsatisfied dependency:
Cannot satisfy dependency:
To: org.eclipse.emf.cheatsheets
Dirk
Am 10.01.2013 18:16, schrieb Ed Merks:
> Dirk,
>>> Dirk,
>> Tried to run
>> ./eclipsec.exe \
>> -tag FetchEMF \
>> -profile SDKProfile
>> but that failed.
>>>> Hi,
>>>> I found
>>>> Regards,
>>>> Dirk
Re: [GWT] Where to download the runtime components [message #999071 is a reply to message #999052] Fri, 11 January 2013 04:20 Go to previous messageGo to next message
Dirk,
Did you pick just the EMF GWT Runtime feature? It doesn't depend on the
things you mention below.
On 11/01/2013 9:25 AM, Dirk Hoffmann wrote:
> Hi Ed,
> From: org.eclipse.emf.doc.feature.group
> Regards,
> Dirk
>> Dirk,
>>>> Dirk,
>>> Tried to run
>>> ./eclipsec.exe \
>>> -repository
>>> -tag FetchEMF \
>>> -profile SDKProfile
>>> but that failed.
>>>>> Hi,
>>>>> I found
>>>>> Regards,
>>>>> Dirk
Re: [GWT] Where to download the runtime components [message #999146 is a reply to message #999071] Fri, 11 January 2013 07:56 Go to previous messageGo to next message
Hi Ed,
thanks again.
Being more selective about the features and unchecking "Include required
software" did help.
In which situations would I need the other EMF GWT features?
I had to remove some app-engine related stuff from the run configuration
and eventually succeeded in getting the editor running in development mode.
Actually I do not want to deploy the application to the app engine, just
to an ordinary J2EE servlet container.
Under WEB-INF/lib I see a number of jars, some of them related to the
app engine, others I have no clue what they are for.
Can I remove some of them?
Dirk
Am 11.01.2013 10:20, schrieb Ed Merks:
> Dirk,
>> Hi Ed,
>> Regards,
>> Dirk
>>> Dirk,
>>>>> Dirk,
>>>> Tried to run
>>>> ./eclipsec.exe \
>>>> -repository
>>>> -tag FetchEMF \
>>>> -profile SDKProfile
>>>> but that failed.
>>>>>> Hi,
>>>>>> I found
>>>>>> Regards,
>>>>>> Dirk
Re: [GWT] Where to download the runtime components [message #999153 is a reply to message #999146] Fri, 11 January 2013 08:12 Go to previous message
Dirk,
Comments below.
On 11/01/2013 1:56 PM, Dirk Hoffmann wrote:
> Hi Ed,
> thanks again.
> required software" did help.
The target stuff you need target platform. The rest are just
sub-features of the SDK feature. When developing you'd want the full
SDK. When deploying your application (the Java portion for the server),
you'd need the EMF GWT runtime feature.
> configuration and eventually succeeded in getting the editor running
> just to an ordinary J2EE servlet container.
See what happens, but most are there because AppEngine or GWT want the
to be there.
> Regards,
> Dirk
>> Dirk,
>>> Hi Ed,
>>> Regards,
>>> Dirk
>>>> Dirk,
>>>> such a
>>>>>> Dirk,
>>>>> Tried to run
>>>>> ./eclipsec.exe \
>>>>> -repository
>>>>> -tag FetchEMF \
>>>>> -profile SDKProfile
>>>>> but that failed.
>>>>>>> Hi,
>>>>>>> I found
>>>>>>> Regards,
>>>>>>> Dirk
Previous Topic:[CDO] Exception when removing objects from a list, obtained with query
Next Topic:No source code is available for type java.util.regex.Pattern
Current Time: Wed Jul 23 05:24:15 EDT 2025
Powered by FUDForum. Page generated in 0.08541 seconds
