Home » Eclipse Projects » P2 » Update site build replacing qualifier(When I build my update site it replaces the version qualifier with a concrete value)
Update site build replacing qualifier [message #998511] Thu, 10 January 2013 01:25 Go to next message
Basically when I build my update site the first time it works fine. The versions of the features used are just 1.0.0.qualifier.
However when it does the build it replaces the '.qualifier' with the actual concrete value.
When I try to build the update site again at a later time it complains that it can't find the features between the version range [previous concrete qualifier, previous concrete qualifier], obviously because the qualifier has moved on!
It doesn't happen all the time but it is happening consistently enough to be a big stumbling block in what should be a smooth update process. When it does complain about not being able to find the correct version I have to go into the site.xml and replace the concrete qualifier with '.qualifier' again.
Any suggestions what could be causing my problem?
Re: Update site build replacing qualifier [message #998676 is a reply to message #998511] Thu, 10 January 2013 08:45 Go to previous messageGo to next message
you are referring to legacy update site, not p2 repository, right?
> '.qualifier' again.
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Update site build replacing qualifier [message #998883 is a reply to message #998676] Thu, 10 January 2013 17:23 Go to previous message
Whoops my bad - yeah I'm talking about the legacy update site. I'll repost my question on the PDE forum
Previous Topic:where is p2.director ant target defined?
Next Topic:create category for site?
Current Time: Sat Jul 26 08:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.06335 seconds
