Home » Modeling » TMF (Xtext) » Using Xtext to populate memody model
Using Xtext to populate memody model [message #997820] Tue, 08 January 2013 15:14 Go to next message
Hi, I'm new to Xtext but not to antlr, I used antlr in the past to parse dsl and create a java model in memory.
I like what Xtext is doing and saw the code generator example but I don't see how I could generate objects at parse time.
I must be missing some step to accomplish this...
Re: Using Xtext to populate memody model [message #997931 is a reply to message #997820] Tue, 08 January 2013 21:22 Go to previous messageGo to next message
There is no step... simple load the file into an EMF resource set and
the parser will be triggered, parse, link, etc. and give you the model
contents.
Also, other models can simply refer to model elements in the created
model without knowing that it is in fact a text based DSL.
How you do this differs slightly depending on if you are running inside
the IDE (while editing etc.) or if you want some stand alone tool that
performs the reading.
If you want to read the model for purpose of "building", the best way is
to hook into the Xtext builder framework - thus getting a callback when
things change, simply read the model and do whatever you want.
Need to know a bit more about what you want to do in order to be more
specific.
Hope this helps along the way.
- henrik
Re: Using Xtext to populate memody model [message #998142 is a reply to message #997820] Wed, 09 January 2013 07:38 Go to previous messageGo to next message
Are you asking how to generate the java model in memory at parse time
(as you do in antlr)? If this is what you ask, then you don't have to
worry about that: Xtext will generate the AST model for you while parsing :)
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Using Xtext to populate memody model [message #998158 is a reply to message #997931] Wed, 09 January 2013 08:10 Go to previous messageGo to next message
Thanks, I already have the model build (java classes), all I want is to populate it based on the parsed text.
What is the xtext build framework? Do you mean the generator?
Re: Using Xtext to populate memody model [message #998197 is a reply to message #998158] Wed, 09 January 2013 09:44 Go to previous message
That happens when loading it as an EMF resource.
No. Builders that run in the IDE. It is described in the documentation.
- henrik
Previous Topic:Help with scoping please.
Next Topic: Using Xtext code in an Eclipse Plugin
Current Time: Wed Jul 23 18:27:38 EDT 2025
Powered by FUDForum. Page generated in 0.16022 seconds
