Home » Modeling » EMF » Loading resource from jar file(Loading resource from jar file with relative url)
Loading resource from jar file [message #997543] Tue, 08 January 2013 03:50 Go to next message
I am trying to load a resource (*.ecore) file within a jar file with relative location to jar file.
Here is an example:
jar:file:/../../com.example.model.jar!/model/com.example.basemodel.ecore
But loading this file as a resource throws FileNotFoundException for the jar file.
I have cross checked the path of jar file and the path of ecore inside it.
Providing an absolute path to the jar file works fine.
Can anyone help me get this working with relative path?
thanks,
Pradeep
Re: Loading resource from jar file [message #997658 is a reply to message #997543] Tue, 08 January 2013 04:09 Go to previous messageGo to next message
Pradeep,
Try archive: and be sure the thing after the file: is really an archive
that exists. I assume you don't really have file:/.. as part of the
path; that makes little sand will depend on what your current
directory. Use File.getAbsolutePath to create this part of your URI and
be sure that File.exists is true.
On 08/01/2013 9:50 AM, Pradeep Badiger wrote:
> Here is an example:
> the jar file.
> it.
> thanks,
> Pradeep
Re: Loading resource from jar file [message #997791 is a reply to message #997658] Tue, 08 January 2013 13:51 Go to previous messageGo to next message
Hi Ed,
I am trying it on the EMF editor (Load Resource dialog provided by the EMF editor). I dont have the option to use any API as you mentioned.
I was wondering, if its really possible to have relative path for the resource within a jar file.
I have the jar file containing a resource placed relatively to the ecore file where i am trying to load.
Please let me know if I have clearly defined my problem.
Let me know your thoughts.
thanks,
Pradeep
Re: Loading resource from jar file [message #997982 is a reply to message #997791] Wed, 09 January 2013 00:34 Go to previous messageGo to next message
Pradeep,
No, as I said, if it works at all, its interpreted relative to the
current directory of the process, and what's that for the running IDE
and how do you know nothing changes it? So use an absolute path. If
it's in the workspace you could use
jar:platform:/resource/<project>/<path>/<jar>!/<path-in-jar>.
On 08/01/2013 7:51 PM, Pradeep Badiger wrote:
> Hi Ed,
> thanks,
> Pradeep
Re: Loading resource from jar file [message #998075 is a reply to message #997982] Wed, 09 January 2013 05:27 Go to previous messageGo to next message
Thanks Ed.
I kept the jar file in the project where it has to be loaded and used your approach to load the resource.
I observered one thing using this approach. If i make any changes in the loaded resource and copy the jar file into the path where it is referenced, and if i open the file referencing this resource, i dont see changes that i made in the loaded resource.
I checked the Temp folder where it had created a cache for this loaded jar file and it is not getting updated, till i close the ide and reopen it again.
Do you know how we can avoid a cache for such resource?
thanks,
Pradeep
Re: Loading resource from jar file [message #998097 is a reply to message #998075] Wed, 09 January 2013 06:15 Go to previous messageGo to next message
Pradeep,
Comments below.
On 09/01/2013 11:27 AM, Pradeep Badiger wrote:
> Thanks Ed.
> referenced,
I don't follow... Where was the jar before you referenced it? What
resource is loaded? What are you changing?
Which resource?
Where did you make the changes? Have you saved any changes?
> jar file
Why are you doing that?
Hmmm. Maybe something to do with using JarFile...
I'm not sure I understand the problem. Maybe you can create a
self-contained test case and open a bugzilla so I can have a look at that?
> thanks,
> Pradeep
Re: Loading resource from jar file [message #998494 is a reply to message #998097] Thu, 10 January 2013 00:23 Go to previous messageGo to next message
Steps to reproduce the issue
1. Run "mvn clean install" on com.example.basemodel project
2. Run "mvn clean" on com.example.model project. This will copy the com.example.basemodel.jar to the target folder of com.example.model project.
3. Load resource from model.ecore within com.example.model project.
using - jar:platform:/resource/com.example.model/target/com.example.basemodel.jar!/model/basemodel.ecore
4. Now check the class name within the loaded resource. It should have "Person" class within the "basemodel" package.
5. Rename the "Person" class to "NewPerson" within basemodel.ecore in com.example.basemodel project.
6. Repeat steps 1, 2 and 3.
7. Now if you check the class within the loaded resource, the class name still remains as "Person", whereas it should have been "NewPerson".
8. If IDE is restarted and step 3 is repeated, then one can see the changes made in the basemodel.ecore which is loaded in model.ecore
In my workspace, i will never have the com.example.basemodel project to build. I will copy it to my com.example.model project and add the reference.
[Updated on: Thu, 10 January 2013 01:01] by Moderator
Re: Loading resource from jar file [message #998534 is a reply to message #998494] Thu, 10 January 2013 02:25 Go to previous messageGo to next message
Pradeep,
Comments below.
What's mvn?
Why would you need to do such a thing? I'd expect they're plugin
projects with a proper dependency...
If I recall correctly, a jar: URL will open a JarFile and will keep it
open for the lifetime of the JVM...
Try using archive: instead.
> 5. Rename the "Person" class to "NewPerson" within com.example.basemodel project.
This seems to that step 2 didn't actually update the jar, which makes
sense if the jar is locked because there's an open stream on it. Have
you confirmed the jar really is updated by your step 2? But then again,
the jar: URL itself might keep an in memory copy... Not sure, but a jar:
URI is handled as just a URL, so whatever Java does for a URL with jar
protocol, that's beyond my control... Try archive: instead; it has the
same semantics, but is implemented to load/save using ZipFile/ZipStream.
> 8. If IDE is restarted and then if step 3 is repeated, then one can see the changes made in the basemodel.ecore which is loaded in model.ecore
Do you generate code from these models?
Re: Loading resource from jar file [message #998560 is a reply to message #998534] Thu, 10 January 2013 03:37 Go to previous message
Hi Ed,
First two steps are for just to quickly get started on the projects.
I used archive: now instead of jar: and it is working fine for me.
I would be generating java code from the model files. I am using Texo for generating code. But I see that using the archive: doesnt work when i generate code having reference to other model file. Whereas, using jar: works fine.
I will have to check Texo's implementation and raise a question on TEXO forum.
thanks for your help.
regards,
Pradeep
Previous Topic:Code Generator broken in EMF 2.8.x and Eclipse 3.8 / 4.2?
Next Topic:EMF and SOAP - how?
Current Time: Wed Jul 23 01:55:52 EDT 2025
Powered by FUDForum. Page generated in 0.07413 seconds
