Content Assist stops working [message #997358] |
Sun, 06 January 2013 19:33  |
When running the DSL, content assist works fine on one line, and the next line it stops working.
While debugging through to see what is happening, I can see that no proposals are being added for the point where it starts failing, but I can't work out why.
While fiddling with this to try to add some more details, I created a new grammar instance and pasted in bits until it started failing.
RENAME DIAGRAM "User 14" TO "Technical Reference Model S"
(works up to here)
RENAME SYMBOL "User 2" to "Component Instance"
(stops working here)
The problem is "to".
If I change this to "TO" it starts working again.
So it has something todo with case insensitivity.
The grammar doesn't give me any errors, so it is parsing correctly.
Just content assist stops working.
Anyone have some clues?
Re: Content Assist stops working [message #997617 is a reply to message #997358] |
Mon, 07 January 2013 12:11   |
Am 07.01.13 01:33, schrieb Barrie Treloar:
> can't work out why.
> (works up to here)
Did you configure case insensitivity for the content assist parser, too?
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: Content Assist stops working [message #998057 is a reply to message #997882] |
Wed, 09 January 2013 04:25  |
Hi Barrie,
I think you did use the
parser.antlr.ex.ca.ContentAssistParserGeneratorFragment
instead of the
parser.antlr.ex.rt.AntlrGeneratorFragment, didn't you?
Sebastian
Am 09.01.13 00:13, schrieb Barrie Treloar:
> Sebastian Zarnekow wrote on Mon, 07 January 2013 12:11
> That's a fair call Sebastian.
> I dont think so.
> {MyDsl.mwe2}
> fragment = parser.antlr.ex.rt.AntlrGeneratorFragment {
> options = {
> // ignore case keywords
> ignoreCase = true
> fragment = contentAssist.JavaBasedContentAssistFragment {}
> // generates a more lightweight Antlr parser and lexer
> tailored for content assist
> fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
> I had read
> http://zarnekow.blogspot.com.au/2010/06/new-in-xtext-case-insensitive-languages.html
> before, but its taken a few reads to digest what it is saying as well as
> the context of actually needing to make those changes.
> After replacing
> with
> options = {
> ignoreCase = true
> content assist starts working again.
> Thanks.
FUDForum. Page generated in 0.04936 seconds
