Home » Eclipse Projects » Eclipse 4 » Problems with launching Eclipse 4 applications
Problems with launching Eclipse 4 applications [message #997264] Fri, 04 January 2013 15:11 Go to next message
I see a lot of questions which relates to problem with launching the Eclipse 4 application therefore I created this list to check what problem you may face:
Eclipse 4 typical launch problems
Re: Problems with launching Eclipse 4 applications [message #997603 is a reply to message #997264] Sat, 05 January 2013 14:12 Go to previous messageGo to next message
> http://www.vogella.com/articles/EclipseRCP/article.html#runconfiguration_problems
hi Lars, thanks for your help but i see your article and i follow it
but i have this error when i run a simple example
my System:
Eclipse for RCP and RAP developers Version: Juno Service Release 1 Build
id: 20120920-0800;i use windows 7 64 bit,
best regads and excuse me fo my bad english
Antonio
log error:
!SESSION 2013-01-05 20:05:38.372
eclipse.buildId=unknown
java.version=1.7.0_10
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Framework arguments: -product com.example.rcp.wizard.product
Command-line arguments: -product com.example.rcp.wizard.product -data
C:\work/../runtime-com.example.rcp.wizard.product -dev
file:C:/work/.metadata/.plugins/org.eclipse.pde.core/com.example.rcp.wizard.product/dev.properties
-os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2013-01-05 20:05:49.154
!MESSAGE Product com.example.rcp.wizard.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2013-01-05 20:05:50.365
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.366
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.10.2.v20120814-175454.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt 2 0 2013-01-05
20:05:50.366
!MESSAGE Missing imported package org.w3c.dom.css_2.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.367
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.css.core_0.10.2.v20120806-171245.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.core 2 0 2013-01-05 20:05:50.368
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.369
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt.theme 2 0 2013-01-05 20:05:50.370
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.371
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.services_0.10.2.v20120726-172631.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.services 2 0 2013-01-05 20:05:50.371
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.372
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.10.2.v20120802-184737.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.373
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.374
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.e4.ui.css.swt_0.10.2.v20120821-165957.jar
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt 2 0 2013-01-05 20:05:50.374
!ENTRY org.eclipse.osgi 2 0 2013-01-05 20:05:50.642
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.645
!MESSAGE Bundle org.eclipse.e4.ui.css.swt_0.10.2.v20120821-165957 [1]
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt 2 0 2013-01-05 20:05:50.648
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.core_0.9.0.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt 2 0 2013-01-05 20:05:50.650
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.653
!MESSAGE Bundle org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624
[3] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt.theme 2 0 2013-01-05 20:05:50.656
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt_0.9.1.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt.theme 2 0 2013-01-05 20:05:50.658
!SUBENTRY 2 org.eclipse.e4.ui.css.swt.theme 2 0 2013-01-05 20:05:50.661
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.663
!MESSAGE Bundle
org.eclipse.e4.ui.workbench.renderers.swt_0.10.2.v20120814-175454 [21]
was not resolved.
20:05:50.666
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench_0.9.0.
20:05:50.669
!MESSAGE Missing required bundle org.eclipse.e4.ui.services_0.9.0.
20:05:50.684
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench.swt_0.9.0.
20:05:50.687
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt.theme_0.9.0.
20:05:50.689
20:05:50.692
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.694
!MESSAGE Bundle org.eclipse.e4.ui.workbench_0.10.3.v20120822-140642 [35]
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench 2 0 2013-01-05 20:05:50.697
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.699
!MESSAGE Bundle org.eclipse.e4.ui.css.core_0.10.2.v20120806-171245 [40]
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.core 2 0 2013-01-05 20:05:50.702
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.705
!MESSAGE Bundle org.eclipse.e4.ui.services_0.10.2.v20120726-172631 [49]
was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.services 2 0 2013-01-05 20:05:50.707
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.710
!MESSAGE Bundle org.eclipse.e4.ui.workbench.swt_0.10.2.v20120802-184737
[52] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.712
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench_0.10.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.715
!MESSAGE Missing required bundle org.eclipse.e4.ui.services_0.1.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.717
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.720
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt_0.9.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.723
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-01-05 20:05:50.725
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-01-05 20:05:50.898
!MESSAGE Bundle com.example.rcp.wizard_1.0.0.qualifier [59] was not
resolved.
!SUBENTRY 2 com.example.rcp.wizard 2 0 2013-01-05 20:05:50.900
!MESSAGE Missing required bundle org.eclipse.e4.ui.services_0.10.2.
!SUBENTRY 2 com.example.rcp.wizard 2 0 2013-01-05 20:05:50.903
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench_0.10.3.
!SUBENTRY 2 com.example.rcp.wizard 2 0 2013-01-05 20:05:50.905
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench.swt_0.10.2.
!SUBENTRY 2 com.example.rcp.wizard 2 0 2013-01-05 20:05:50.908
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.core_0.10.2.
!ENTRY org.eclipse.osgi 4 0 2013-01-05 20:05:50.912
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Problems with launching Eclipse 4 applications [message #997604 is a reply to message #997603] Sun, 06 January 2013 02:00 Go to previous messageGo to next message
Antonio,
Are these missing plugins specified in your run configuration?
> my System:
> Build id: 20120920-0800;i use windows 7 64 bit,
> Antonio
> log error:
> java.vendor=Oracle Corporation
> root constraints are not resolved:
> !MESSAGE Bundle
> was not resolved.
> 20:05:50.366
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> 20:05:50.666
> 20:05:50.669
> 20:05:50.684
> 20:05:50.687
> 20:05:50.689
> 20:05:50.692
> [35] was not resolved.
> [40] was not resolved.
> [49] was not resolved.
> !MESSAGE Bundle
> org.eclipse.e4.ui.workbench.swt_0.10.2.v20120802-184737 [52] was not
> resolved.
> resolved.
> !STACK 1
> at
> at
> at
> at
> at
> at
Re: Problems with launching Eclipse 4 applications [message #997606 is a reply to message #997604] Sun, 06 January 2013 13:50 Go to previous messageGo to next message
Hi Ed,
i have the plug in that is read in error log, i see org.eclipse.osgi
and don't have problem.
i follow the article of Lars Vogel now in com.example.e4.rcp.wizard.product
i click label depencies i see this plugin have a error (i see red box
whit white x)
org.eclipse.core.filesystem.aix.ppc
org.eclipse.core.filesystem.hpux.ia64_32
org.eclipse.core.filesystem.linux.ppc
org.eclipse.core.filesystem.linux.x86
org.eclipse.core.filesystem.linux.x86_64
org.eclipse.core.filesystem.macosx
org.eclipse.core.filesystem.solaris.sparc
org.eclipse.core.filesystem.win32.x86
org.eclipse.core.resources.win32.x86
org.eclipse.swt.carbon.macosx
org.eclipse.swt.cocoa.macosx
org.eclipse.swt.cocoa.macosx.x86_64
org.eclipse.swt.gtk.linux.ppc
org.eclipse.swt.gtk.linux.ppc64
org.eclipse.swt.gtk.linux.s390
org.eclipse.swt.gtk.linux.s390x
org.eclipse.swt.gtk.linux.x86"
org.eclipse.swt.gtk.linux.x86_64
org.eclipse.swt.gtk.solaris.sparc
org.eclipse.swt.gtk.solaris.x86
org.eclipse.swt.motif.aix.ppc
org.eclipse.swt.motif.hpux.ia64_32
org.eclipse.swt.motif.linux.x86
org.eclipse.swt.motif.solaris.sparc
org.eclipse.swt.photon.qnx.x86
org.eclipse.swt.win32.win32.x86
i think this is the problem,
thx
Antonio
Il 06/01/2013 08:00, Ed Merks ha scritto:
> Antonio,
>> my System:
>> Antonio
>> log error:
>> !MESSAGE Bundle
>> was not resolved.
>> 20:05:50.366
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> was not resolved.
>> !MESSAGE Bundle
>> was not resolved.
>> 20:05:50.666
>> 20:05:50.669
>> 20:05:50.684
>> 20:05:50.687
>> 20:05:50.689
>> 20:05:50.692
>> !MESSAGE Bundle
>> resolved.
>> resolved.
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Problems with launching Eclipse 4 applications [message #997704 is a reply to message #997606] Tue, 08 January 2013 10:21 Go to previous message
The plugins listed are not the problem, they are platform specific and filtered out.
Try generating a new e4 application with the wizard and starting your e4 application from the product configuration file.
Delete any existing launch configuration.
Previous Topic:Open editor using CompatibilityEditor
Next Topic:Creating a console view in the RCP Application
Current Time: Sat Jul 26 02:41:22 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
