Home » Archived » Visual Editor (VE) » Problem installing ve
Problem installing ve [message #99739] Mon, 25 July 2005 05:55 Go to next message
Originally posted by: alexandre.mazari.hectic.fr
Hi guys,
I am currently trying to install ve 1.1 without success, here is the
context :
- eclipse 3.1 installed via apt-get under ubuntu breezy
- gef 3.1 installed via eclipse's update manager
- emf 2.1 installed via eclipse's update manager
- ve 1.1 supposedely installed by unzipping the archive in my eclipse
installed dir (/usr/share/eclipse previously chmoded to allow user writing)
After launching 'eclipse -clean', ve doesn't appear in the 'Manage
Configuration' window.
Does any of you has some clue about that kind of issue and better a
solution.
thanks in advance,
Alexandre
Re: Problem installing ve [message #99809 is a reply to message #99739] Mon, 25 July 2005 08:56 Go to previous messageGo to next message
Hi Alexandre,
Trying to understand, so in your plugins/ folder you have plugins which
have different owners? Please make sure that the plugins extracted have
the same 'user, group and other' permissions set on them as the rest of
the eclipse plugins.
Sri.
alexandre mazari wrote:
> Hi guys,
> context :
> solution.
> thanks in advance,
> Alexandre
Re: Problem installing ve [message #100025 is a reply to message #99739] Mon, 25 July 2005 16:02 Go to previous message
> Hi guys,
> context :
> writing)
> solution.
remove all except config.ini in directory ECLIPSE_HOME/configuration and
restart eclipse
regards
Re: Problem installing ve [message #609222 is a reply to message #99739] Mon, 25 July 2005 08:56 Go to previous message
Hi Alexandre,
Sri.
> Hi guys,
> context :
> solution.
> thanks in advance,
> Alexandre
Re: Problem installing ve [message #609237 is a reply to message #99739] Mon, 25 July 2005 16:02 Go to previous message
> Hi guys,
> context :
> writing)
> solution.
restart eclipse
regards
Previous Topic:how to install ve 1.1?
Next Topic:NPE when leave VE Editor (Swing) up when close / reopen Eclipse
Current Time: Fri Aug 01 21:07:11 EDT 2025
Powered by FUDForum. Page generated in 0.04171 seconds
