Home » Newcomers » Newcomers » Eclipse Now Fails To Load
Eclipse Now Fails To Load [message #997250] Fri, 04 January 2013 12:11 Go to next message
The logo appears, then disappears and fails to load now. I'm not sure what has happened, but I was able to find the log and post it below. If someone could assist, it would be greatly appreciated.
!SESSION 2013-01-04 12:06:38.067 -----------------------------------------------
eclipse.buildId=M20110909-1335
java.version=1.7.0_10
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.osgi 4 0 2013-01-04 12:06:41.311
!MESSAGE An error occurred while automatically activating bundle org.eclipse.mylyn.tasks.ui (224).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start() of bundle org.eclipse.mylyn.tasks.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.util.Util.safeLoadExecutableExtension(Util.java:879)
at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.createContributionItem(DynamicToolBarContributionItem.java:183)
at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.getContributionItem(DynamicToolBarContributionItem.java:176)
at org.eclipse.ui.internal.menus.DynamicToolBarContributionItem.createControl(DynamicToolBarContributionItem.java:278)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:97)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88)
at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265)
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3867)
at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3878)
at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1150)
at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1036)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1211)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/mylyn/internal/provisional/commons/ui/CommonFonts
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start(TasksUiPlugin.java:553)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 70 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.mylyn.internal.provisional.commons.ui.CommonFonts
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
... 74 more
Root exception:
... 74 more
!ENTRY org.eclipse.ui 4 4 2013-01-04 12:06:41.322
!MESSAGE Class load Failure: 'org.eclipse.mylyn.internal.tasks.ui.TaskTrimWidget'
!ENTRY org.eclipse.ui 4 0 2013-01-04 12:06:41.322
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.mylyn.tasks.ui was unable to load class org.eclipse.mylyn.internal.tasks.ui.TaskTrimWidget.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.mylyn.tasks.ui (224).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 52 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start() of bundle org.eclipse.mylyn.tasks.ui.
... 64 more
... 70 more
... 74 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-01-04 12:06:41.323
!MESSAGE Plug-in org.eclipse.mylyn.tasks.ui was unable to load class org.eclipse.mylyn.internal.tasks.ui.TaskTrimWidget.
!STACK 0
... 64 more
... 70 more
... 74 more
!ENTRY org.eclipse.ui 4 0 2013-01-04 12:06:41.326
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.jface.action.ControlContribution.computeWidth(ControlContribution.java:54)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:100)
!ENTRY org.eclipse.core.jobs 2 2 2013-01-04 12:06:41.748
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.ide.IDEWorkbenchActivityHelper$4
Re: Eclipse Now Fails To Load [message #997397 is a reply to message #997250] Mon, 07 January 2013 05:12 Go to previous messageGo to next message
I see that the root error is:
Which Eclipse bundle are you using? And which version of Mylyn? And on which operating system? Did you install or update Mylyn manually?
You may want to ask the Mylyn guys directly on their forum or have a look at this bug which seems somewhat related to your issue.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: Eclipse Now Fails To Load [message #997445 is a reply to message #997397] Mon, 07 January 2013 09:43 Go to previous message
Stephane Begaudeau wrote on Mon, 07 January 2013 05:12
Thanks Stephane. I resorted to re-installing Eclipse (Indigo) again to clear the error. It seemed to happen when I installed the Google Web Toolkit, which I haven't reinstalled since. Mylyn was done automatically, not manually. Also, I'm running Windows Vista Ultimate 64-bit. Running Eclipse on Linux (Ubuntu 12.04) however has been rock solid.
Glenn
Previous Topic:Eclipse with PHP
Next Topic:Project creation on remote systems
Current Time: Sat Jul 26 11:18:57 EDT 2025
Powered by FUDForum. Page generated in 0.32711 seconds
