| How to move a report item from one page to the previous. [message #997183] |
Fri, 04 January 2013 05:04  |
I have a table, each of its row contains an image (its size is as wide and as hight as the page except header and footer) and a grid.
I would like to move that grid up, so it will overlap the image like below
I do that by setting top margin to the grid -50mm. The problem is, it cant produce PDF report. The PDF is corrupted and there is stacktrace:
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.drawBorder(PageDeviceRender.java:1086)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.drawTableBorder(PageDeviceRender.java:1306)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.endContainer(PageDeviceRender.java:585)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.visitContainer(PageDeviceRender.java:185)
at org.eclipse.birt.report.engine.nLayout.area.impl.ContainerArea.accept(ContainerArea.java:274)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.visitChildren(PageDeviceRender.java:195)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.visitContainer(PageDeviceRender.java:184)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.addPage(PageDeviceRender.java:540)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.visitPage(PageDeviceRender.java:505)
at org.eclipse.birt.report.engine.layout.emitter.PageDeviceRender.visitContainer(PageDeviceRender.java:179)
at org.eclipse.birt.report.engine.layout.emitter.PageEmitter.startPage(PageEmitter.java:51)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.outputPage(LayoutEngine.java:892)
at org.eclipse.birt.report.engine.nLayout.area.impl.PageArea.outputPage(PageArea.java:696)
at org.eclipse.birt.report.engine.nLayout.area.impl.PageArea.close(PageArea.java:676)
at org.eclipse.birt.report.engine.nLayout.area.impl.RootArea.close(RootArea.java:241)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.closeContainer(LayoutEngine.java:374)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine._endContainer(LayoutEngine.java:486)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.endContainer(LayoutEngine.java:359)
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.endPage(ContentEmitterAdapter.java:70)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.endPage(CompositeContentEmitter.java:171)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.endContent(ContentEmitterUtil.java:102)
at org.eclipse.birt.report.engine.layout.html.buffer.PageNode.end(PageNode.java:33)
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.endPage(HTMLPageBuffer.java:292)
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.endContainer(HTMLPageBuffer.java:136)
at org.eclipse.birt.report.engine.layout.html.buffer.TableBreakBuffer.endContainer(TableBreakBuffer.java:421)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.end(HTMLPageLM.java:183)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:98)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
If I change the image height so both, the image and the grid are on one page, then it works, but the image is not as high as the page.
How can I do that? Thanks
Attachment: report.png
(Size: 833.03KB, Downloaded 1744 times)
[Updated on: Fri, 04 January 2013 05:59] by Moderator
FUDForum. Page generated in 0.03255 seconds
