Home » Newcomers » Newcomers » update, uninstall, or leave the country?(Having trub updating an old version)
icon9.gif  update, uninstall, or leave the country? [message #997123] Thu, 03 January 2013 15:13 Go to next message
Wow, I thought I posted about my problems, but it's nowhere to be found. Win XP sp3
0. I installed Eclipse about 2-3 years ago for a Java course I took and have seldom used it since. I'm about to start another course that will use Java so I need Eclipse again.
1. I went to check for updates under the help menu and the front screen, and it said there are none! Yet there is of course a newer version. This is what I have now: Version: Helios Service Release 2
Build id: 20110301-1815
BTW that happens to me every time both with Eclipse and Aptana. Check for Updates has never worked. If it works for others, I must be doing something wrong. What? That is my first problem/question.
2. I downloaded the latest Eclipse IDE for Java Developers. Should I uninstall my current version before I do anything else? Because I can't unzip the new file to my Program Files folder because there would be two eclipse folders.
3. I tried unzipping and running the new version and got several requests for a password so I could download a file. One file was pom.xml IIRC. I tried dismissing these but they kept coming up so I canceled the whole thing and came here for help.
4. My first post disappeared! Please don't delete this! I need Eclipse.
Re: update, uninstall, or leave the country? [message #997136 is a reply to message #997123] Thu, 03 January 2013 17:15 Go to previous messageGo to next message
> found. Win XP sp3
The "check for updates" only checks for things for that release you have
.... Helios Service Release 2 was the "last" service for Helios. While
some "tricks" might accomplish you to update it, To Indigo or Juno, I'd
recommend starting with fresh download (from Juno, SR1 ... the latest
release, Juno SR2 due out the 4th Friday of February, 2013 ... so, you
could update then! :)
You can rename the folder "eclipse" to something like
"eclipseHeliosSR2". That might break some of your shortcuts or similar,
but once you run the eclipse executable under that folder, everything
should still work. That's what I do ... rename ... though admit I
usually do it "at the beginning" after unzipping it.
This request for password, while unzipping, is one sign of windows not
well handling the large zip files from Eclipse. This is a "known issue"
and several alternatives are listed in
http://wiki.eclipse.org/SDK_Known_Issues
Hope one of them works for you.
Re: update, uninstall, or leave the country? [message #997138 is a reply to message #997123] Thu, 03 January 2013 17:23 Go to previous message
> Win XP sp3
> eclipse folders.
1. I'll leave this to someone else.
2. You have done the right thing. As Eclipse isn't really installed, you
can just explode the zip file alongside the existing one (that is, in a
subdirectory alongside, but not in or under the existing one). If it
were me, I'd rename the old one "eclipse-helios" and the new one
"eclipse" since it's the one you're going to use. When or if you wish to
free up the disk space, just drag the old (eclipse-helios) folder into
the trash; make sure any workspace folder (with code you want to keep)
isn't down under that one (normally not the case).
3. I'm not sure what you're seeing here. There should be no passwords or
permissions trouble as you're on XP not Vista/7/8. You should have
downloaded a zip file from eclipse.org and you're unzipping it to where
you want to put it. Under Windows 7, this would be C:\Users\linda, but
under XP, I always just placed it on C:\eclipse since it was the most
important piece of software I was going to use. Glance at
http://wiki.eclipse.org/SDK_Known_Issues to make sure your choice of zip
program isn't affecting you.
4. We aim to please and won't delete your post. Someone else will fill
in with the detail I couldn't manage for you.
Best of luck!
Previous Topic:"Egit could not detect where GIT is installed"
Next Topic:eclipse galileo stops working
Current Time: Sun Jul 27 14:15:37 EDT 2025
Powered by FUDForum. Page generated in 0.08870 seconds
