Home » Modeling » TMF (Xtext) » Xtext grammar for real literals and filenames with a . dot extension
Xtext grammar for real literals and filenames with a . dot extension [message #996670] |
Wed, 02 January 2013 11:42  |
I have the following grammar defined, but have an issue with detecting real literals, after adding support for detecting filenames with a . dot extension.
The real expressions used to work, prior to adding support for detecting filenames with extensions
Failed tests
real 1312.123e+123
real 1312.123
real 1312_1312.123_123
real 1312_1312.123123e+123
real 1234.1232e-234234
real 1234.123123E+1232
include <header>
Passed tests
include "filename"
include "filename.txt"
include <filename.txt>
include <filename.txt.bak>
Terminals.xtext
grammar com.example.mydsl.xtext.common.Terminals hidden(WS, ML_COMMENT, SL_COMMENT)
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
// Identifiers
terminal identifier : '^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
// Comments and whitespace
terminal ML_COMMENT : '/*' -> '*/';
terminal SL_COMMENT : '//' !('\n'|'\r')* ('\r'? '\n')?;
terminal WS : (' '|'\t'|'\r'|'\n')+;
// Integer literals
terminal sign : ('+' | '-');
terminal binDigits : ('0' | '1')+;
terminal binDigitsUnderscore : (binDigits | '_')*;
//terminal octDigits : ('0' | '1'..'7' '0'..'7'*);
//terminal octDigitsUnderscore : (octDigits | '_')*;
terminal decDigits : ('0'..'9')+;
terminal decDigitsUnderscore : (decDigits | '_')*;
terminal hexDigitsUnderscore : ('0'..'9' | 'a'..'f' |'A'..'F' | '_')+;
bitWidth : decDigits;
decNum : (decDigits | decDigitsUnderscore)?;
baseLiteral : ('b' | 'B') binDigitsUnderscore
// | ('o' | 'O') octDigitsUnderscore
| ('d' | 'D') decDigitsUnderscore
| ('h' | 'H') hexDigitsUnderscore;
unsizedIntLiteral : ( sign? decNum ) | ( sign? baseLiteral );
sizedIntLiteral : bitWidth baseLiteral;
intLiteral : '0' | '1'
| sizedIntLiteral
| unsizedIntLiteral;
// Real literals
realLiteral hidden() : decNum '.' (expDecDigits|decNum);
terminal expDecDigits : (decDigits ('e' | 'E') sign? decDigits);
// String literals
terminal stringLiteral :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|'"') )* '"' |
"'" ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|"'") )* "'"
terminal filenameLiteral :
// Identify filenames in the following format:
// filename.txt, filename (i.e., without the . filename extension)
( ('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ('.' ('a'..'z'|'A'..'Z'|'_'|'0'..'9')* )* )
// Bug: terminal filenameLiteral: include <filename> does not work without a file extension.
mydsl.xtext
MyDSLDomainModel:
elements += AbstractElement*;
AbstractElement:
IncludeDirective | DefineDirective | IntegerToken | RealToken;
// Compiler directives
// File inclusion: include and line
IncludeDirective:
'include' filename=stringLiteral
| 'include' '<' filename=filenameLiteral '>'
// Macro definition and substitutions: define and related directives
DefineDirective:
'define' macroName=identifier //(macroText=(identifier | intLiteral | realLiteral))?
IntegerToken:
'integer' name=(unsizedIntLiteral | binDigits | binDigitsUnderscore | hexDigitsUnderscore);
RealToken:
'real' name=realLiteral;
How can I fix the grammar so that I am able to detect real numbers, plus filenames with a . dot extension?
Elvis Dowson
[Updated on: Wed, 02 January 2013 11:43] by Moderator
Re: Xtext grammar for real literals and filenames with a . dot extension [message #996690 is a reply to message #996670] |
Wed, 02 January 2013 12:17   |
This has been asked and answered earlier in this forum. See if you can
find it by searching for "REAL" - I posted an example of how I solved it.
If you can't find it, ping again, and I will dig it up.
- henrik
On 2013-02-01 17:42, Elvis Dowson wrote:
> Failed tests
> real 1312.123e+123
> real 1312.123
> include <header>
> Passed tests
> include "filename"
> Terminals.xtext
> grammar com.bluespec.mydsl.xtext.common.Terminals hidden(WS, ML_COMMENT,
> SL_COMMENT)
> // Identifiers
> // Integer literals
> | sizedIntLiteral
> | unsizedIntLiteral;
> // Real literals
> // String literals
> mydsl.xtext
> MyDSLDomainModel:
> AbstractElement:
> IncludeDirective:
> DefineDirective:
> IntegerToken:
> RealToken:
> Elvis Dowson
Re: Xtext grammar for real literals and filenames with a . dot extension [message #996801 is a reply to message #996712] |
Wed, 02 January 2013 18:27   |
On 2013-02-01 19:31, Elvis Dowson wrote:
> Hi Henrik,
> I searched the TMF forums for the word "REAL" and looked up
> posts with your name, but couldn't find the appropriate solution. The
> word "REAL" is too generic, to attempt to try against the whole forum!
> If you could locate it or let me know where I'm going wrong, it would be
> great!
> Best regards,
> Elvis Dowson
ok
Here are the relevant portions of the b3 grammar that shows how I dealt
with both real numbers and integers in hex/octal/decimal.
Hope this helps...
- henrik
IntegerLiteral returns be::BExpression : {be::BLiteralInteger}
value= RadixIntValue
RealLiteral returns be::BExpression : {be::BLiteralExpression}
value = RealValue
// Has conversion rule
RealValue returns ecore::EDoubleObject: REAL ;
// Has conversion rule that handles decimal, octal, and hexadecimal
values but returns an Integer
IntValue returns ecore::EIntegerObject : INT | HEX ;
values with radix
RadixIntValue returns ecore::EJavaObject : INT | HEX ;
terminal HEX : '0' ('x'|'X')(('0'..'9')|('a'..'f')|('A'..'F'))+ ;
terminal INT : ('0'..'9')+;
REAL hidden(): INT '.' (EXT_INT | INT); // INT ? '.' (EXT_INT | INT);
terminal EXT_INT: INT ('e'|'E')('-'|'+') INT;
Here is some additional code to reuse - or get it from github...
https://github.com/eclipse/b3/tree/master/org.eclipse.b3.beelang/src/org/eclipse/b3
terminal converters
@ValueConverter(rule = "RealValue")
public IValueConverter<Double> RealValue() {
return new IValueConverter<Double>() {
public String toString(Double value) {
return value.toString();
public Double toValue(String string, AbstractNode node) {
if(Strings.isEmpty(string))
throw new ValueConverterException("Could not convert empty string
to double", node, null);
try {
return new Double(string);
catch(NumberFormatException e) {
throw new ValueConverterException("Could not convert '" + string +
"' to double", node, null);
@ValueConverter(rule = "RadixIntValue")
public IValueConverter<IntegerWithRadix> RadixIntValue() {
return new IValueConverter<IntegerWithRadix>() {
public String toString(IntegerWithRadix value) {
public IntegerWithRadix toValue(String string, AbstractNode node)
throws ValueConverterException {
int radix = 10;
throw new ValueConverterException("Can not convert empty string to
int", node, null);
try {
if(string.startsWith("0x") || string.startsWith("0X")) {
radix = 16;
string = string.substring(2);
else if(string.startsWith("0") && string.length() > 1)
radix = 8;
return new IntegerWithRadix(Integer.valueOf(string, radix), radix);
String format = "";
switch(radix) {
case 8:
format = "octal";
break;
case 10:
format = "decimal";
break;
case 16:
format = "hexadecimal";
break;
"Can not convert to " + format + " integer : " + string, node, null);
and if you need it - integer with radix
* Copyright (c) 2010, Cloudsmith Inc.
* The code, documentation and other materials contained herein have been
* licensed under the Eclipse Public License - v 1.0 by the copyright
holder
* listed above, as the Initial Contributor under such license. The text of
* such license is available at www.eclipse.org.
package org.eclipse.b3.backend.core.datatypes;
import java.io.Serializable;
* A representation of an integer with a radix
public class IntegerWithRadix implements Serializable {
private static final long serialVersionUID = 3249927626857631021L;
private Integer value;
private int radix;
public IntegerWithRadix(int value) {
this.value = new Integer(value);
this.radix = 10;
public IntegerWithRadix(int value, int radix) {
if(!(radix == 8 || radix == 10 || radix == 16))
throw new IllegalArgumentException("Only radix 8, 10 or 16 supported");
this.value = value;
this.radix = radix;
public int getRadix() {
return radix;
public Integer getValue() {
return value;
public String toString() {
StringBuffer buf = new StringBuffer();
if(radix == 8)
buf.append("0");
else if(radix == 16)
buf.append("0x");
buf.append(Integer.toString(value, radix));
return buf.toString();
Re: Xtext grammar for real literals and filenames with a . dot extension [message #996816 is a reply to message #996801] |
Wed, 02 January 2013 19:34   |
Should have pointed out that REAL is not a terminal.
I had issues with supporting real numbers without an integral part e.g.
..3e2 (as you can see that is commented out). I decided that the solution
was good enough with a requirement to write that as 0.3e2.
Also worth mentioning, in a later grammar (different language) I
switched to using an external lexer, and if I had to do this again, I
would use that approach to produce INT, HEX, OCTAL, or REAL tokens since
it is possible to do more powerful things when lexing with this approach.
- henrik
>> Hi Henrik,
>> great!
>> Best regards,
>> Elvis Dowson
> ok
> Hope this helps...
> Regards
> - henrik
> value = RealValue
> values with radix
> terminal converters
> convert empty string to double", node, null);
> try {
> convert '" + string + "' to double", node, null);
> node) throws ValueConverterException {
> int radix = 10;
> empty string to int", node, null);
> try {
> radix = 16;
> radix = 8;
> radix), radix);
> String format = "";
> switch(radix) {
> case 8:
> format = "octal";
> break;
> case 10:
> format = "decimal";
> break;
> case 16:
> break;
> holder
> text of
> private int radix;
> this.radix = 10;
> supported");
> this.value = value;
> this.radix = radix;
> return radix;
> return value;
> @Override
> if(radix == 8)
> buf.append("0");
> buf.append("0x");
Re: Xtext grammar for real literals and filenames with a . dot extension [message #996916 is a reply to message #996816] |
Thu, 03 January 2013 02:21  |
make filename a datatype rule and not a terminal rule. Actually, this applies to almost all your terminal rules. Not everything has to be dealt with in the grammar. In most cases it is better to have datatype rules and value converters throwing meaningful errors. Overlapping terminal rules are a pain, in particular if you don't really know how the terminals work.
Alex
Current Time: Wed Jul 23 05:23:33 EDT 2025
Powered by FUDForum. Page generated in 0.29250 seconds
