Home » Language IDEs » PHP Development Tools (PDT) » how to use WSDL editor in Indigo
how to use WSDL editor in Indigo [message #707088] Mon, 01 August 2011 04:15 Go to next message
Hi, I have been working on SOAP with PHP in eclipse for a while. When using Helios, the WSDL editor helped much. However, I can't find such editor in the new Indigo. All I can get is the WSDL explorer, which I have no idea if it can be used with PHP.
Any advice?
Re: how to use WSDL editor in Indigo [message #707127 is a reply to message #707088] Mon, 01 August 2011 05:09 Go to previous messageGo to next message
> be used with PHP.
> Any advice?
Use Soap Ui - this is great WSDL tool that allows mocks, responses and many more
wsdl related operations. I'm using it for few years now.
/dmc
Re: how to use WSDL editor in Indigo [message #707771 is a reply to message #707127] Mon, 01 August 2011 23:08 Go to previous messageGo to next message
Thanks for the suggestion. But I was using the editor to modify WSDL files. Is there any way to modify WSDL files inside Eclipse, just like the WSDL editor in Helios?
[Updated on: Mon, 01 August 2011 23:09] by Moderator
Re: how to use WSDL editor in Indigo [message #707895 is a reply to message #707771] Tue, 02 August 2011 03:33 Go to previous messageGo to next message
You need to install additional "Eclipse Java Web Developer Tools".
Re: how to use WSDL editor in Indigo [message #728773 is a reply to message #707895] Fri, 23 September 2011 17:53 Go to previous messageGo to next message
There's a WSDL tool? If only I knew that back when I had to mess with SOAP and WSDL files Sad
Re: how to use WSDL editor in Indigo [message #757912 is a reply to message #728773] Wed, 16 November 2011 07:56 Go to previous messageGo to next message
> WSDL files :(
Yes, there is, and it works great :)
/dmc
Re: how to use WSDL editor in Indigo [message #996146 is a reply to message #707895] Tue, 01 January 2013 01:17 Go to previous message
Thanx and it helps well..
Previous Topic:Cannot install PDT as plugin in Eclipse Classic 4.2
Next Topic:How to add file to project?
Current Time: Mon Jul 21 23:24:14 EDT 2025
Powered by FUDForum. Page generated in 0.06430 seconds
