Problem with importURI and standalone generator [message #995180] |
Sat, 29 December 2012 04:39  |
Hello all,
I have the following grammar (the url of eclipse.org have been replaced to escape forum restrictions) :
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "eclipse-org-site/xtext/common/JavaVMTypes" as jvmTypes
generate myDsl "xtext-org-site/example/mydsl/MyDsl"
Model: (greetings+=Greeting | imports+=Import | goodbyes+=Goodbye)*;
Greeting: "Hello" name=ID;
Import: "import" importURI=STRING;
Goodbye: "Bye" ref=[Greeting] ;
The generator is a simple one, just to test:
public class MyDslGenerator implements IGenerator {
public void doGenerate(Resource resource, IFileSystemAccess fsa) {
StringBuilder output = new StringBuilder();
Iterator<?> it = resource.getAllContents();
while (it.hasNext()) {
Object o = it.next();
if (o instanceof Greeting) {
output.append("Hello " + ((Greeting) o).getName() + "\n");
} else if (o instanceof Goodbye) {
output.append("Goodbye " + ((Goodbye) o).getRef().getName() + "\n");
fsa.generateFile(resource.getURI().lastSegment() + ".output", output);
With the following file test3.mydsl:
import "test2/test2.mydsl"
Hello aek
Bye aek
Bye eak
test2/test2.mydsl simply contains "Hello eak". It works perfectly fine in the Eclipse launch but if I call org.xtext.example.mydsl.generator.Main on test3.mydsl, I get the following error:
ERROR:Couldn't resolve reference to Greeting 'eak'. (src/test3.mydsl line : 6)
Has anyone any clue on how to resolve that?
A subsidiary thing which is not blocking but that I'd like to have working is to be able to use jvmTypes in the same times that I can use importURI but it seems that the TypesGeneratorFragment is needed for jvmTypes but it stop importURI feature from working.
Thank you all for the help.
FUDForum. Page generated in 0.06847 seconds
