Home » Archived » M2M (model-to-model transformation) » [ATL] Several problems
[ATL] Several problems [message #99462] |
Wed, 11 February 2009 22:23  |
Originally posted by: aaniculaesei.gmail.com
I'm transforming a UML statemachine model to NuSMV.
The UML model contains two statemachines. However I get information
printed out in the output file for only one statemachine.
Moreover, the output file doesn't seem to be organized in a manner that
would show me which states or transitions belong to which statemachine.
The matched rule of my transformation looks like this:
rule StateMachine2Module {
from
s : UML!StateMachine
to
t : NuSMV!TModule (
moduleName <- s.name,
define <- s.region->select(r | r.subvertex->select(v |
not v.isInitial and not v.isFinal)
->collect(v | thisModule.Vertex2Define(v)) ),
variable <- s.region->select(r | r.subvertex->select(v |
v.isInitial)->collect(v |thisModule.InitialState2Init(v))),
assign <- s.region->select(r | r.transition->select(t |
t.source.isPseudostate)->collect(t |
thisModule.TransitionFromPseudostate2Assign(t)))
The rules called in the matched rule are unique lazy rules.
This rule works partially, meaning it gives me the "moduleName" and the
elements of the collection "define" for example. If in addition to the
"define" elements I try to print out the "variable" or the "assign"
elements , the result is the same, as if these lines corresponding to
them were commented in code of the rule.
I have never actually managed to make an ATL matched rule work with more
then two assignments in the target. However, I've seen many examples
which show that this is possible. I don't know what I'm doing wrong here.
Any help would be much appreciated.
Thanks in advance
Adina
Re: [ATL] Several problems [message #99508 is a reply to message #99462] |
Thu, 12 February 2009 03:29   |
I think we can't help without more information
why do you use unique lazy rules and not matching rules in your rule ?
what does the rule matching elements containing your statemachine ?
Adina Aniculaesei a écrit :
> Hello,
> from
> to
> t : NuSMV!TModule (
> Thanks in advance
> Adina
Re: [ATL] Several problems [message #99562 is a reply to message #99547] |
Thu, 12 February 2009 06:14   |
Hi again !
I think there is some misunderstanding please see comments bellow and
i'm sure we will success !
> Hi
> Tristan FAURE wrote:
>> Hi
> If in the rule of the statemachine I call matched rules for the elements
> contained in the statemachine, in the output file I get only empty tags
> like:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:NuSMV=" file:/D:/Documents/TOP-MAAT-Praktikum/workspace-atl/Uml2NuSm v/NuSMV.xsd ">
> <NuSMV:TModule/>
> <NuSMV:TModule/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TDefine/>
> <NuSMV:TInitVarValue/>
> </xmi:XMI>
> However if I call lazy rules, the output file looks like this:
> <NuSMV:TModule moduleName="SM_Client"/>
> <NuSMV:TModule/>
> <NuSMV:TDefine defName="State_0"/>
> <NuSMV:TDefine defName="State_1"/>
> <NuSMV:TDefine defName="State_2"/>
> <NuSMV:TDefine defName="State_3"/>
> <NuSMV:TDefine defName="State_4"/>
> <NuSMV:TDefine defName="FinalState_0"/>
> </xmi:XMI>
First it will be good to have your meta model target but it seems that
NuSMV:TModule is your top level element ? if it is the case i found
strange that you want a tree with multiple roots ? maybe you should
reconsider a new metamodel with a top level containing (containment
relation) modules ?
> I want to have something like this:
> -- first state machine translated in NuSMV
> <NuSMV:TModule moduleName="SM_Client">
> <NuSMV:TModule/>
> -- second state machine translated in NuSMV
> <NuSMV:TModule moduleName="SM_Lock">
> <NuSMV:TModule/>
> </xmi:XMI>
> or at least:
> <NuSMV:TModule moduleName="SM_Lock"/>
> -- and here the elements of the second state machine
> I only used the unique lazy rules thinking I could get it better, but it
> has the same effect as when calling lazy rules.
In you atl file you have one matching rule as i said before for each
state machine atl will create a new Module if it is the top level
element it won't succeed what i imagine
a top matching level rule {
Model to ModuleContainer (
modules <- UML!StateMachine.allIstances() ; -- with this assignment
atl will look for matching rules matching state machines
all your lazy rules transformed in matching rules, it's better enhance
your guards to not have for one input element two rules matching
and keep your StateMachine rule dropping called to lazy rules
for first tests keep only the creation of modules !
Regards !
> I attached the ATL file, to see how the rules correponding to the
> elements of the state machine look like and how they are called.
> I appreciate your help very much.
> Adina
>>> Hello,
>>> that would show me which states or transitions belong to which
>>> statemachine.
>>> from
>>> to
>>> t : NuSMV!TModule (
>>> | thisModule.TransitionFromPseudostate2Assign(t))) )
>>> the elements of the collection "define" for example. If in addition
>>> to the "define" elements I try to print out the "variable" or the
>>> "assign" elements , the result is the same, as if these lines
>>> corresponding to them were commented in code of the rule.
>>> more then two assignments in the target. However, I've seen many
>>> examples which show that this is possible. I don't know what I'm
>>> doing wrong here.
>>> Thanks in advance
>>> Adina
Re: [ATL] Several problems [message #99911 is a reply to message #99804] |
Fri, 13 February 2009 03:14   |
Hi we advance a little
I checked your metamodel and ...
i think your top level rule is
-- @top level rule
rule Model2ModuleContainer {
from
s : UML!Model
to
t : NuSMV!DocumentRoot(
nuSMVModel <- model
model : NuSMV!TNuSMV(
modules <- someModules
someModules : NuSMV!TModules(
module <- UML!StateMachine.allInstances()
rule StateMachine2TModule (
from s : UML!StateMachine
Maybe you should consider this for starting and for atl keyword maybe
you should rename it and regenerate your metamodel api :/
> Hello,
> Thank you for your answers until now.
> I wrote the following rule to call the rule for each instance of the
> state machine.
> -- @top level rule
> from
> s : UML!UML
> to
> t : NuSMV!TModules (
> The output file is empty after running this rule. I tried to call on
> every instance the rule for state machine, but to no result.
> That is, I made the rule for state machine as "lazy"
> and in the target I wrote:
> module <- UML!StateMachine.allInstances()->collect(sm |
> sm.thisModule.StateMachine2Module(sm))
> Also do you know what can I do if an element of the target model has the
> same name as an atl keyword ? In this case is the word "module" which
> happens to be a component of the NuSMV type TModules. "module" is in
> this case a sequence of one or more modules, each module being of type
> TModule.
> I attached the metamodel file and the XSD file correponding to it.
> I tried to modify both of them replacing the word "module" but it didn't
> work.
> Thanks again
> Adina
>> Hi again !
>>> Hi
>>>> Hi
>>> elements contained in the statemachine, in the output file I get only
>>> empty tags like:
>>> <NuSMV:TModule/>
>>> <NuSMV:TModule/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> <NuSMV:TDefine/>
>>> </xmi:XMI>
>>> <NuSMV:TModule/>
>>> </xmi:XMI>
>> relation) modules ?
>>> <NuSMV:TModule/>
>>> <NuSMV:TModule/>
>>> </xmi:XMI>
>>> or at least:
>>> it has the same effect as when calling lazy rules.
>> assignment atl will look for matching rules matching state machines
>> Regards !
>>> Adina
>>>>> Hello,
>>>>> statemachine.
>>>>> from
>>>>> to
>>>>> t : NuSMV!TModule (
>>>>> doing wrong here.
>>>>> Thanks in advance
>>>>> Adina
Re: [ATL] Several problems [message #99971 is a reply to message #99911] |
Fri, 13 February 2009 14:15   |
Thanks for the top level rule. It works nice. Also the fact that
"module" is a keyword of atl language doesn't seem to make a
difference, that is no errors, no warnings, contrary to what I've expected.
Now I try to print out the states of each state machine, but they are
shown outside the corresponding <module> tag and outside of the
<DocumentRoot> tag.
The rule is:
from
to
t : NuSMV!TModule (
define <- s.region->select(r | r.subvertex->select(v | not
->union(s.region->select(r | r.subvertex
->select(v | v.isFinal)->collect(v |
thisModule.FinalState2Define(v))))
I try to access the containing state machine, but it doesn't work.
from
to
t : NuSMV!TModule (
define <- UML!Vertex.allInstances()->select(v | s =
v.containingStateMachine())
Thanks in advance for any help.
Adina
> -- @top level rule
> from
> s : UML!Model
> to
> nuSMVModel <- model
>> Hello, Thank you for your answers until now.
>> state machine.
>> -- @top level rule
>> from
>> s : UML!UML
>> to
>> the same name as an atl keyword ? In this case is the word "module"
>> which happens to be a component of the NuSMV type TModules. "module"
>> is in this case a sequence of one or more modules, each module being
>> of type TModule.
>> didn't work.
>> Thanks again
>> Adina
>>> Hi again !
>>>> Hi
>>>>> Hi
>>>> only empty tags like:
>>>> <NuSMV:TModule/>
>>>> <NuSMV:TModule/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> <NuSMV:TDefine/>
>>>> </xmi:XMI>
>>>> <NuSMV:TModule/>
>>>> </xmi:XMI>
>>> that NuSMV:TModule is your top level element ? if it is the case i
>>> found strange that you want a tree with multiple roots ? maybe you
>>> should reconsider a new metamodel with a top level containing
>>> (containment relation) modules ?
>>>> <NuSMV:TModule/>
>>>> <NuSMV:TModule/>
>>>> </xmi:XMI>
>>>> or at least:
>>>> but it has the same effect as when calling lazy rules.
>>> enhance your guards to not have for one input element two rules matching
>>> Regards !
>>>> Adina
>>>>>> Hello,
>>>>>> information printed out in the output file for only one statemachine.
>>>>>> statemachine.
>>>>>> from
>>>>>> to
>>>>>> t : NuSMV!TModule (
>>>>>> and the elements of the collection "define" for example. If in
>>>>>> addition to the "define" elements I try to print out the
>>>>>> "variable" or the "assign" elements , the result is the same, as
>>>>>> if these lines corresponding to them were commented in code of the
>>>>>> rule.
>>>>>> with more then two assignments in the target. However, I've seen
>>>>>> many examples which show that this is possible. I don't know what
>>>>>> Thanks in advance
>>>>>> Adina
Re: [ATL] Several problems [message #99989 is a reply to message #99971] |
Fri, 13 February 2009 14:44   |
Hi again,
I should also mention that I left the rules called by the state machine
rule as lazy rules. If I turn them to match rules the only thing I get
are empty NuSMV tags <NuSMV:TDefine/> outside the top level element,
which in this case is <module>.
Many thanks
Adina
Adina Aniculaesei wrote:
> Hi
> <DocumentRoot> tag.
> The rule is:
> from
> to
> t : NuSMV!TModule (
> from
> to
> t : NuSMV!TModule (
> = v.containingStateMachine())
> Adina
>> -- @top level rule
>> from
>> s : UML!Model
>> to
>> nuSMVModel <- model
>>> state machine.
>>> -- @top level rule
>>> from
>>> s : UML!UML
>>> to
>>> sm.thisModule.StateMachine2Module(sm)) Also do you know what can I
>>> do if an element of the target model has the same name as an atl
>>> keyword ? In this case is the word "module" which happens to be a
>>> component of the NuSMV type TModules. "module" is in this case a
>>> sequence of one or more modules, each module being of type TModule.
>>> didn't work.
>>> Thanks again
>>> Adina
>>>> Hi again !
>>>> and i'm sure we will success !
>>>>> Hi
>>>>>> Hi
>>>>>> rule ?
>>>>> <NuSMV:TModule/>
>>>>> <NuSMV:TModule/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> <NuSMV:TDefine/>
>>>>> </xmi:XMI>
>>>>> <NuSMV:TModule/>
>>>>> </xmi:XMI>
>>>>> <NuSMV:TModule/>
>>>>> <NuSMV:TModule/>
>>>>> </xmi:XMI>
>>>>> or at least:
>>>> matching
>>>> Regards !
>>>>> Adina
>>>>>>> Hello,
>>>>>>> statemachine.
>>>>>>> manner that would show me which states or transitions belong to
>>>>>>> which statemachine.
>>>>>>> from
>>>>>>> to
>>>>>>> t : NuSMV!TModule (
>>>>>>> the rule.
>>>>>>> Thanks in advance
>>>>>>> Adina
Re: [ATL] Several problems [message #100017 is a reply to message #99989] |
Mon, 16 February 2009 03:33   |
Hi if your elements are outside the model it's a containment problem as
i see in your metamodel define is correctly set to containment at true.
Is this value changed ? did you regenerate api when it changes ?
if it never changed maybe you should use debug('') expression on your
selects to see if your ocl expressions worked ..;
> Hi again,
> Many thanks
> Adina
>> Hi
>> expected.
>> <DocumentRoot> tag.
>> The rule is:
>> from
>> to
>> t : NuSMV!TModule (
>> from
>> to
>> t : NuSMV!TModule (
>> Adina
>>> -- @top level rule
>>> from
>>> s : UML!Model
>>> to
>>> nuSMVModel <- model
>>>> state machine.
>>>> -- @top level rule
>>>> from
>>>> s : UML!UML
>>>> to
>>>> didn't work.
>>>> Thanks again
>>>> Adina
>>>>> Hi again !
>>>>>> Hi
>>>>>>> Hi
>>>>>>> rule ?
>>>>>> <NuSMV:TModule/>
>>>>>> <NuSMV:TModule/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> <NuSMV:TDefine/>
>>>>>> </xmi:XMI>
>>>>>> <NuSMV:TModule/>
>>>>>> </xmi:XMI>
>>>>>> <NuSMV:TModule/>
>>>>>> <NuSMV:TModule/>
>>>>>> </xmi:XMI>
>>>>>> or at least:
>>>>> each state machine atl will create a new Module if it is the top
>>>>> level element it won't succeed what i imagine
>>>>> matching
>>>>> Regards !
>>>>>> Adina
>>>>>>>> Hello,
>>>>>>>> statemachine.
>>>>>>>> which statemachine.
>>>>>>>> from
>>>>>>>> to
>>>>>>>> t : NuSMV!TModule (
>>>>>>>> the rule.
>>>>>>>> Thanks in advance
>>>>>>>> Adina
Re: [ATL] Several problems [message #102074 is a reply to message #100017] |
Thu, 19 March 2009 22:58   |
--------------050202010906020103030205
Hello Tristan,
Thanks for all the help until now and sorry to get back to you so late
with a feedback. I've run the Debug on my ATL code and I get the
following error messages in console:
SEVERE: ********************************* ERROR
SEVERE:
java.lang.Exception
at
org.eclipse.m2m.atl.engine.vm.NetworkDebugger.error(NetworkD ebugger.java:165)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:91)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:103)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at
at
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.debug(AtlLauncher.jav a:105)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:324)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.access$0(AtlR egularVM.java:408)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM$1.run(AtlRegu larVM.java:386)
SEVERE: Message: ERROR: could not find operation not on Sequence(OclAny)
having supertypes: [Collection(OclAny)]
SEVERE: A.main() : ??#42 null
SEVERE: local variables = {self=Uml2NuSmv : ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#18 null
SEVERE: local variables = {self=Uml2NuSmv : ASMModule, e=TransientLink
{rule = 'StateMachine2Module', sourceElements = {s =
flattUml!SM_Client}, targetElements = {t = nusmv!<unnamed>}, variables =
SEVERE: A.__applyStateMachine2Module(1 : NTransientLink;) : ??#53
59:14-60:52
SEVERE: local variables = {t=nusmv!<unnamed>, null=flattUml!State_4,
s=flattUml!SM_Client, self=Uml2NuSmv : ASMModule, r=flattUml!Region_0,
link=TransientLink {rule = 'StateMachine2Module', sourceElements = {s =
SEVERE: local stack = [nusmv!<unnamed>, nusmv!<unnamed>, Uml2NuSmv :
ASMModule, Sequence {}]
SEVERE:
SEVERE:
java.lang.Exception
at
at
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:173)
at
at
at
at
at
at
at
at
at
at
at
at
SEVERE: org.eclipse.m2m.atl.engine.vm.nativelib.ASMSequence
java.lang.ClassCastException:
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:319)
at
at
at
at
at
at
at
at
at
at
at
at
at
SEVERE: A.__applyStateMachine2Module(1 : NTransientLink;) : ??#54
59:14-60:52
ASMModule]
SEVERE:
What does the following error message mean:
I attached the transformation file.
Many thanks in advance.
Adina
> Adina Aniculaesei a
Re: [ATL] Several problems [message #102089 is a reply to message #102074] |
Fri, 20 March 2009 05:09  |
--------------040006070107000700000609
Hello again,
I've revised the transformation in order not to have as a condition for
select something like this:
but the output is just the same, in console as well as in the output file.
It looks like it doesn't find the "not" operation on a sequence or on
the elements of a sequence. Why does it do that I have no idea.
Adina
> Hello Tristan,
> SEVERE:
> java.lang.Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> e=TransientLink {rule = 'StateMachine2Module', sourceElements = {s =
> 59:14-60:52
> SEVERE:
> SEVERE:
> java.lang.Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 59:14-60:52
> ASMModule]
> SEVERE:
> Adina
>> as i see in your metamodel define is correctly set to containment at
>> true.
>> Adina Aniculaesei a
Current Time: Sat Jul 26 18:56:35 EDT 2025
Powered by FUDForum. Page generated in 0.06452 seconds
