Home » Eclipse Projects » Eclipse Scout » Auto refresh page
Auto refresh page [message #994891] Fri, 28 December 2012 10:23 Go to next message
Is there any way to auto refresh a table page periodically?
For RAP client, I may be able to add a auto refresh meta header in the page itself so that it will auto refresh, but for swing or swt client what are the possible way to do this?
Re: Auto refresh page [message #994912 is a reply to message #994891] Fri, 28 December 2012 11:13 Go to previous messageGo to next message
This depends on what you want to achieve. There are basically two ways, the client can take actions "on its own":
  • Notification: If you want the client to take some action when a certain event happens on the server, use a "client notification". See here and here for more information.
  • Polling: If you want to simlate "periodically pressing F5" (e.g. to visually monitor some data), create and start your own client job. If that job is asynchronous (i.e. extends ClientAsyncJob) it is run as a background and is not visible to the user. When you want to change something in the Scout model (e.g. replacing all rows in a table), you have to get synchronous again. Here is a quick example:
    // (add this code somewhere in the initialization part of your page)
    new ClientAsyncJob("my async background job", ClientSession.get()) {
      protected void runVoid(IProgressMonitor monitor) throws Throwable {
        while (!stopCondition) {
          // (***1***) Do some background work here, or just Thread.sleep(...)
          new ClientSyncJob("synchronize with Scout model thread", ClientSession.get()) {
              // (***2***) update Scout model, e.g. myPage.reload();
          }.schedule();
    }.schedule();
    This pattern might look slightly confusing, but is actually quite common. Code at location ***1*** is executed in the background and may take long, while code ***2*** is executed in the foreground (visible to the user) and should not take too long (because other user actions have to wait until it's done).
Does that already help you?
Re: Auto refresh page [message #994936 is a reply to message #994912] Fri, 28 December 2012 12:18 Go to previous message
I think for my case, polling looks like a good solution, I will give it a try.
Previous Topic:"Crowdwriting" the Eclipse Scout Book (Feedback Thread)
Next Topic:P/Users, does not match outer scope rule
Current Time: Thu Jul 24 18:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.03298 seconds
