Home » Eclipse Projects » Eclipse Scout » Trouble with images being cached(How to suppress image caching when using IImageField (or Icons in tables))
Trouble with images being cached [message #991136] |
Mon, 17 December 2012 08:10  |
I have succesfully tried adding an image to a table page by following the description on Display_images_in_a_table_page howto. This works well for displaying "static" images in a table (I tried this on the company table page of the minicrm tutorial by just using a server side stored image whose name is identical to the company short name).
Next, I extended the CompanyForm to also display this image using an ImageField. This, too, worked nicely.
As a next step I added an image column to the person table page and added an ImageField to the PersonForm. Instead of using a "static" image I added the functionality to let the user choose an arbitrary image file to display (using a button from the company form) and then storing this image in the database (using a blob in a seperate table, accessed using the personNr). This, too, works in principle.
I soon noticed, that this works with the first image being set (either when a user adds an image for the first time or when first displaying an image from the DB after restarting the application). However, if I try to change the image assigned to a user, I started running into problems. The new data was being sent back to the database and stored, but both the ImageField in the form and the column in the table still displayed the old image.
After some debugging, I found out the following:
Both the icon in the table column and the ImageField use SwingIconLocator.getIcon() which in turn calls SwingIconLocator.getImage() to retrieve the image data. getImage() uses m_imagesByNameCache and as far as I could tell, there is no way to invalidate this cache from the client side.
I was using "Person-"+personNr as imageId on the client side (and the image cache described in the Howto linked above explicitely allows for udpating a caches image). However, the Swing client does not take this into account and keeps using the old image, that is cached in m_imagesByNameCache.
One solution would probably be for me to use a has over the image data as imageId to make sure the imageId/imageName changes with new content. However, over time this would make the swing side image cache contain tons of stale objects.
As I'm trying to learn as much about Swing as I can, I tried a different approach. I created a custom control that I named "UncachedImageField". In order to do this, I took the following steps:
In my scout client plugin I added the following files:
- IUncachedImageField (a copy of IImagegeField)
- IUncachedImageFieldUIFacade (a copy of IImageFieldUIFacade)
- UncachedImageFieldEvent (a copy of ImageFieldEvent)
- UncachedImagedFieldListener (a copy of ImageFieldListener)
- AbstractUncachedImageField (a copy of AbstractImageField)
These files are 1:1 copies of the corresponding ImageField classes with the exception that they reference each other instead of the originals).
In my scout swing ui plugin I added the following files:
- ISwingScoutUncachedImagedField (a copy of ISwingScoutImageField)
This, too is a 1:1 copy of the original with adjusted references)
- SwingScoutUncachedImageField (a copy of SwingScoutImageField with some modifications)
- adjusting the names to the corresponding classes with "Uncached"
- changing setImageFromScout as follows:
protected void setImageFromScout(String imageId, Object image) {
if (image == null) {
if (imageId != null) {
// try to use uncached image
image = getUncachedIconLocator().getImage(imageId);
// as fallback, use cached image
image = getSwingEnvironment().getImage(imageId);
getSwingImageViewer().setImage(image);
- added the following code to the class:
private SwingUncachedIconLocator m_uncachedIconLocator;
protected SwingUncachedIconLocator getUncachedIconLocator() {
if (m_uncachedIconLocator == null) {
m_uncachedIconLocator = new SwingUncachedIconLocator(getSwingEnvironment().getScoutSession().getIconLocator());
return m_uncachedIconLocator;
- SwingUncachedIconLocator (a copy of SwingIconLocator with some modifications)
public Image getImage(String name) {
if (name == null || AbstractIcons.Null.equals(name) || name.length() == 0) {
return null;
Image img;
synchronized (m_cacheLock) {
//img = m_imagesByNameCache.get(name); // not using cache
//if (img == null && !m_imagesByNameCache.containsKey(name)) { // not using cache
img = createImageImpl(name);
if (img == null) {
img = autoCreateMissingImage(name);
//m_imagesByNameCache.put(name, img); // not using cache
if (LOG.isDebugEnabled()) {
LOG.debug("load image '" + name + "' as " + img);
if (img == null) {
warnImageNotFound(name);
//} // not using cache
return img;
- added the following block to plugin.xml
<formField
active="true"
modelClass="com.bsiag.minicrm.client.ui.form.fields.ext.IUncachedImageField"
name="Uncached Image Field"
scope="default">
<uiClass
class="com.bsiag.minicrm.ui.swing.form.fields.ext.SwingScoutUncachedImageField">
</uiClass>
</formField>
I then changed the ImageField on my Form to be an UncachedImageField instead. With these changes the image on the Form is now updated whenever the user selects a different image. However, I have the feeling that there must be an easier solution to this...
Also, the image in the table column still uses the cached version of the icon locator and I haven't found out how to make that use the uncached icon locator.
So, my questions are:
- what is the recommended way to handle images that can change during the life time of the client? Use constantly changing imageIds (bearing the cost of an overblown cache)? Or is there a more elegant solution I fail to see?
- Instead of copying more than half a dozen files to emulate ImageField except for not using a cache in the icon locator, is there an easier way of changing the behaviour of a an existing FormField?
- how would I need to proceed to make the table column icon use the uncached icon locator (if there is no easier solution to my problem)?
Thanks for any light you can shed on this issue.
Re: Trouble with images being cached [message #991220 is a reply to message #991136] |
Mon, 17 December 2012 15:21   |
Hi Urs
The tutorial basically seems to read the image data and then put it in the icon cache from which it can be retrieved by the string id. So maybe it was designed to cache the icon and never change it again.
Have you tried reading the image data (= byte[]) by yourself and directly setting it into the ImageField by using the method setImage(Object)? For reading a file, Scout's IOUtility may be handy.
This does not work for images in a table, though, because the ImageField is not used there. For an ICell, you can only specify icons "by ID" and not "by data". IDs are then resolved using the SwingEnvironment's icon locator. So, if you override the method createIconLocator() and provide your own (non-caching) SwingIconLocator, you should be able to achieve the desired behavior. As far as I could see at a quick glance, the ImageField also retrieves the icon locator from the SwingEnvironment. If you try that our, please let us know if it worked.
(Note: All classes that use org.eclipse.scout.rt.ui.swing.Activator to retrieve icons and images cannot be changed, because you cannot replace that SwingIconLocator. This mostly "only" affects UI images, like the splash screen and not application-specific icons.)
Regarding your concern about having to copy so many files the create a custom widget: I admit that I did not try it out ( ), but I think in your case it would have to be sufficient to only register a new UncachedSwingScoutImageField class that extends SwingScoutImageField (for 'IImageField'). If I am correct, the most specific (i.e. greatest distance to IFormField) class "wins". Duplicating the model class (AbstractImageField) should not be necessary as you do not want to alter the model behavior. (Note that this approach would then affect all ImageField!)
Does that already help your for your problem? If you think that a mechanism to invalidate the image cache is missing from Scout, maybe we should discuss it further.
Re: Trouble with images being cached [message #991257 is a reply to message #991220] |
Tue, 18 December 2012 02:27   |
Beat Schwarzentrub wrote on Mon, 17 December 2012 21:21The tutorial basically seems to read the image data and then put it in the icon cache from which it can be retrieved by the string id. So maybe it was designed to cache the icon and never change it again.
Yes, I'm sure it was designed for exactly that use case. I wasn't trying to criticise the tutorial. It's just that I'm trying to push a bit further than the tutorials and howto's go and occasionally stumble on a blocking point
Beat Schwarzentrub wrote on Mon, 17 December 2012 21:21Have you tried reading the image data (= byte[]) by yourself and directly setting it into the ImageField by using the method setImage(Object)?
I didn't even realise that there was a setImage method, I'll certainly give that a try.
Beat Schwarzentrub wrote on Mon, 17 December 2012 21:21This does not work for images in a table, though, because the ImageField is not used there. For an ICell, you can only specify icons "by ID" and not "by data". IDs are then resolved using the SwingEnvironment's icon locator. So, if you override the method createIconLocator() and provide your own (non-caching) SwingIconLocator, you should be able to achieve the desired behavior. As far as I could see at a quick glance, the ImageField also retrieves the icon locator from the SwingEnvironment. If you try that our, please let us know if it worked.
Thanks, I hadn't thought of that approach and will try it out. If I understand this correctly though, this will mean the non-caching locator would be used for all users of the SwingEnvironment? That may or may not be desirable... Still, it's an approach to look at.
Beat Schwarzentrub wrote on Mon, 17 December 2012 21:21Regarding your concern about having to copy so many files the create a custom widget: I admit that I did not try it out ( ), but I think in your case it would have to be sufficient to only register a new UncachedSwingScoutImageField class that extends SwingScoutImageField (for 'IImageField'). If I am correct, the most specific (i.e. greatest distance to IFormField) class "wins". Duplicating the model class (AbstractImageField) should not be necessary as you do not want to alter the model behavior.
Thanks. I had first tried that approach but didn't know about this "greatest distance" rule and tried to 'bend' the new class to implement a new interface and step by step ended up adding "just one more" class until I had a full duplicate solution
Beat Schwarzentrub wrote on Mon, 17 December 2012 21:21(Note that this approach would then affect all ImageField!)
Yes, that is clear. Again, this may or may not be desirable.
Beat Schwarzentrub wrote on Mon, 17 December 2012 21:21Does that already help your for your problem? If you think that a mechanism to invalidate the image cache is missing from Scout, maybe we should discuss it further.
For my ImageFields I know have several solutions:
- using my own, full blown custom UncachedImageField implementation (advantage: I can choose which fields are cached and which are uncached)
- extending SwingScoutImageField to use the non-caching locator (disadvantage: all ImageFields will be uncached)
- overwriting createIconLocator (disadvantage: all ImageFields and table icons will be uncached)
- using setImage method (advantage: I can choose which fields are cached and which are uncached)
On the other hand, for the table icons it seems to only solution is:
- overwriting createIconLocator, with the disadvantage that all ImageFields and all table icons will be uncached)
- I suppose I could look at "cloning" all classes used for a TableField (or maybe the TablePage?) to allow for selective uncached icons in cells, but that may be a bit much effort even though it would probably teach me a lot about scout
I will play through the various suggestions you made (though it may be next year, I'm off to attend a two day workshop, and then on holidays after that).
Thanks for your help.
Re: Trouble with images being cached [message #991831 is a reply to message #991257] |
Thu, 20 December 2012 04:47   |
Beat,
I've found some time to try out your various suggestions, here is some feedback:
- using setImage(byte[]) instead of setImageId(String) in the form solves the caching problem
- overwriting SwingEnvironment.createIconLocator() succesfully makes all images uncached (form and tables)
- I then removed all files mirroring the *ImageField classes and only kept my SwingScoutUncachedImageField and SwingUncachedIconLocator classes, I also removed the entry in plugin.xml for the new classes.
I let SwingScoutUncachedImageField inherit from SwingScoutImageField
public class SwingScoutUncachedImageField extends SwingScoutImageField {
and added the following entry to the plugin.xml
<formField
active="true"
modelClass="org.eclipse.scout.rt.client.ui.form.fields.imagebox.IImageField"
scope="default">
<uiClass
</uiClass>
</formField>
This should make my new class the "most distant" for this interface but it seems that this does not work, the setImageFromScout() method was always called on SwingScoutImageField and not on my class. Removing the plugin entry doesn't make a difference.
I don't know if you have any further ideas on this.
I also looked at alternatives to ensure the table icons are updated by using a different imageId. To minimize the number of stale objects in the image cache I didn't want to use a permantently increasing id whenever an image changes. Instead, I am now using an md5 hash over the image contents and store those together with the blob in the DB and return it in the outline service for my icon column. This way, I can check if the image is in the cache of the CustomIconProvider and only need to retrieve it from the blob, if it isn't. If a new icon is chosen the new image gets added to the cache with the MD5 hash of the new image. The old image will stay in the cache, but on the plus side if more than one person uses the same image, that will only be cached once and not multiple times (as it was before, when the personNr was used as imageId).
Overall I think using the MD5 hash as imageId for the table cells and directly using the setImage() method on the form will be the most efficient way to deal with my requirement.
Still, looking at all those alternatives has been an educational exercise
Re: Trouble with images being cached [message #991884 is a reply to message #991831] |
Thu, 20 December 2012 07:11   |
Urs Beeli wrote on Thu, 20 December 2012 04:47This should make my new class the "most distant" for this interface but it seems that this does not work, the setImageFromScout() method was always called on SwingScoutImageField and not on my class. Removing the plugin entry doesn't make a difference.
I just took a deeper look at the code and found that the distance is calculated for the model class and not the UI (a.k.a. "SwingScout...") class, i.e. between IFormField and IImageField. Because both contributions refer to IImageField, they also get the same distance (as you can see from the logged warning). I was mistaken there. (Eventually, the approach can be made to work, when you set the "scope" of your contribution from "default" to "global". But that does only work because no other "global" contributions are present and does not look very elegant to me.)
The other possibility would be to not delegate the creation of IImageField UI objects to the FormFieldFactory, but build them yourself in your own SwingEnvironment:
public ISwingScoutFormField<?> createFormField(JComponent parent, IFormField field) {
if (field instanceof IImageField /* && add further conditions here */) {
SwingScoutUncachedImageField ui = new SwingScoutUncachedImageField();
ui.createField((IImageField) field, this);
decorate(field, ui);
return ui;
return super.createFormField(parent, field);
Urs Beeli wrote on Thu, 20 December 2012 04:47Overall I think using the MD5 hash as imageId for the table cells and directly using the setImage() method on the form will be the most efficient way to deal with my requirement.
I like the idea of using the MD5 hash as a cache value. Looks promising! Thanks for sharing.
Beat
Re: Trouble with images being cached [message #996925 is a reply to message #991884] |
Thu, 03 January 2013 03:01  |
Beat thanks for further looking at the "most distant" issue.
Beat Schwarzentrub wrote on Thu, 20 December 2012 13:11The other possibility would be to not delegate the creation of IImageField UI objects to the FormFieldFactory, but build them yourself in your own SwingEnvironment:
return ui;
That looks like another elegant solution to this, I'll add it to the things to keep in mind. Thanks!
Beat Schwarzentrub wrote on Thu, 20 December 2012 13:11Urs Beeli wrote on Thu, 20 December 2012 04:47Overall I think using the MD5 hash as imageId for the table cells and directly using the setImage() method on the form will be the most efficient way to deal with my requirement.
You're welcome, I'm glad I can return something for all the time you spent on this
Current Time: Sat Jul 26 14:47:25 EDT 2025
Powered by FUDForum. Page generated in 0.14349 seconds
