NoClassDefFound - jexel [message #993210] |
Sun, 23 December 2012 14:15  |
I try to get this tutorial http://www.vogella.com/articles/JavaExcel/article.html to work but I get the NoClassDefFoundError
!SESSION 2012-12-23 20:08:34.796 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_09
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product MEXA.product
Command-line arguments: -product MEXA.product -data D:\eclipse\Workspace/../runtime-MEXA.product -dev file:D:/eclipse/Workspace/.metadata/.plugins/org.eclipse.pde.core/MEXA.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-12-23 20:08:39.208
!MESSAGE Internal Error
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: jxl/read/biff/BiffException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:851)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:744)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:728)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:667)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NoClassDefFoundError: jxl/read/biff/BiffException
at MEXA.handlers.CreateSampleProject.execute(CreateSampleProject.java:40)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 30 more
Caused by: java.lang.ClassNotFoundException: jxl.read.biff.BiffException
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 36 more
The thing is, this does NOT happen, if I wirte the Read-Method in a main function.
I have an appliation project and if I create a class with main method (in which I paste the read funktion of the tutorial) it's alright, if I change the methods name it doesn't. How can that be?
Do I have to specify some dependencies somewhere? To use jexel I just copied the required files into my Project and set the Buildpath accordingly.
[Updated on: Sun, 23 December 2012 14:16] by Moderator
FUDForum. Page generated in 0.04456 seconds
