Reference Question for a goto like statement [message #993395] |
Mon, 24 December 2012 03:56  |
I have generated an xtext project from my ecore model. In my model, I have an EClass called statement which has an attribute called label. Every statement is a subclass of this class. For example, I have a call statement class, and its syntax is defined as:
call returns call
label=EString? 'call' to=[CCElem|Estring] '(' ')'
I want the label of s statement to be optinally defined. Now I have special goto like statement, where the user can refer to a statement by its label. So using the above syntax for call, I want to have something like:
n1 call foo();
call mbar();
goto n1;
The syntax for goto is defined as:
goto returns goto
label=EString? 'goto' st=[statement|EString]
With this rule and the above program segment, I get an error in the goto line saying:
Couldn't resolve reference to Statement 'n1'
Somehow it cannot identify the statement by its label. What am I doing wrong? do you have any suggestions?
Re: Reference Question for a goto like statement [message #993589 is a reply to message #993395] |
Mon, 24 December 2012 17:32  |
By default, the linker links an ID to a feature called "name" in the
target. Since your target uses a feature called "label", this will not
work out of the box. Also note that the reference must be a non
containment reference.
I have not had to change this myself, but I think the issue has been
answered earlier in this forum.
Since your metamodel is an already existing one, I assume you can't
change it (rename "label" to "name") even if this is by far the easiest.
Not sure if it works to add a derived attribute (called "name"), but
should be very quick to find out.
I hope that helps.
Regards and Happy Holidays.
- henrik
On 2012-24-12 21:03, Selim Ciraci wrote:
> call returns call
> like:
> n1 call foo();
> call mbar();
> goto n1;
> goto returns goto
> line saying: Couldn't resolve reference to Statement 'n1'
FUDForum. Page generated in 1.66718 seconds
