Debugging lexer & parser [message #635699] |
Wed, 27 October 2010 14:24  |
Hi all,
what is the quickest & simplest way to visualize the token stream & the AST of a file for debugging purposes?
Thanks in advance,
thSoft
Re: Debugging lexer & parser [message #993446 is a reply to message #993416] |
Mon, 24 December 2012 07:14   |
Use of data rules is good unless you end up with lots of tiny tokens,
have to have long lists of things to include (because 'not' is not
possible), or end up with lots of fiddling with hidden on/off (which has
subtle unwanted effects in several places).
When you reach that point, you can write a more powerful external lexer.
Thought that could be good to know if you start feeling you are digging
yourself into a hole.
- henrik
On 2012-24-12 11:11, Barrie Treloar wrote:
> Alexander Nittka wrote on Mon, 24 December 2012 02:21
>> Hi,
>> is there a reason, you can't make your unquoted string definition a
>> datatype rule rather than a terminal rule?
> Because the common Terminals package does so for Strings? I assumed that
> was the best way for unquoted strings.
> I had looked at
> http://www.eclipse.org/Xtext/documentation.html#parser_rules but it says
> Quote:
>> Character ranges, wildcards, the until token and the negation as well
>> as the EOF token are only available for terminal rules.
> Which I assumed also meant datatype rules.
> Since unquoted string can be anything that does not contain a space in
> it, I couldn't work out how to build this with anything but a Terminal
> rule. Which in the end I just gave up and stripped it back to bare
> bones and made it work with the existing instance of the grammar I had
> to test against.
> I'm still very new to all this, so if you can craft a Datatype Rule I'm
> willing to give it a go.
FUDForum. Page generated in 0.25189 seconds
