Home » Modeling » EMF » Existing XMI, meta-model changes
Existing XMI, meta-model changes [message #992257] Fri, 21 December 2012 03:14 Go to next message
suppose an existing Ecore model instance as serialized XMI. Now the meta
model is changed in a way that a solitary unidirectional reference is
added an opposite. When loading the XMI resource I get an
IndexOutOfBounds exception. SAXXMIHandler.handleForwardReferences seems
to make some fixups ending up in moving an element in a list to a
position, but the list is empty at that point.
I would have expected that the new opposite reference is automatically
populated on loading, but that does not seem to be the case.
What can I do to save the XMI? A fully manually restore on XML level
would be quite difficult I'm afraid.
TIA
Marius
Re: Existing XMI, meta-model changes [message #992839 is a reply to message #992257] Sat, 22 December 2012 14:43 Go to previous messageGo to next message
Marius,
Comments below.
On 21/12/2012 12:14 AM, Marius Gröger wrote:
> Hello,
Do you need both ends serialized? I.e., is marking the new thing
transient is okay or is that a problem?
> TIA
> Marius
Re: Existing XMI, meta-model changes [message #1002002 is a reply to message #992839] Thu, 17 January 2013 12:28 Go to previous messageGo to next message
On 22.12.2012 20:43, Ed Merks wrote:
> Marius,
> Comments below.
>> Hello,
Well I actually had tried that before my post. However, this didn't work
in conjunction with Teneo, which we use in the project. Unfortunately I
don't recall the exact error I got.
It really would be great if there was at least some kind of load option
for this, so I could write some kind of workbench action which "fixes"
such half-complete models.
Marius
Re: Existing XMI, meta-model changes [message #1002235 is a reply to message #1002002] Fri, 18 January 2013 03:19 Go to previous message
Marius,
How broken is the final loaded resource? Note that even if
ResourceSet.getResource(..., true) throws an exception, you can still
call ResourceSet.getResource(..., false) to find the resource that was
loaded and it will have contents to the extent to which they could be
populated during loading (minus the parts it couldn't deal with because
of exceptions). Look at how the generated editor does that...
>> Marius,
>> Comments below.
>>> Hello,
> Regards
> Marius
Previous Topic:[CDO] Diagnostic/Reparation tool
Next Topic:[EMF] Configure code generation to respect existing modelpackage indexes
Current Time: Fri Jul 25 21:39:24 EDT 2025
Powered by FUDForum. Page generated in 0.04505 seconds
