Run as script - sometimes no output [message #99251] |
Sun, 28 June 2009 15:34 |
Sometimes when I run a PHP script using the Run button, I get no output to
console (even if the php.exe already terminated).
Sometimes when I run "longer" scripts I even get only part of output (not
everything - e.g. script that is supposed to output numbers 0 to 20
outputs only numbers from 0 to 7 or from 10 to 20).
It wouldn't be so annoying if it didn't work at all, but it's quite
confusing, because it sometimes works and sometimes it doesn't.
I recorded a video of this:
http://www.screencast-o-matic.com/watch/cQ1tnEfiQ
(you need Java and a good web browser to view it)
I use Eclipse PDT 2.1, PHP 5.2.10 with XDebug 2.0.4 (but there isn't
probably problem in php and xdebug, because when I try to run the script
manually in Command Prompt I always get output).
Please help. I think that there must be some bug in Eclipse, otherwise I
can't explain it.
FUDForum. Page generated in 0.03534 seconds
