Home » Newcomers » Newcomers » Where can I change the background colour of the suggestion popups?
Where can I change the background colour of the suggestion popups? [message #991941] Thu, 20 December 2012 09:18 Go to next message
When I hover over a error, and it give me suggestions how to fix this (as in, importing the relevant classes, implementing missing methods etc etc). This is done in narrow blue writing on a black background, and is borderline impossible to read. I tend to use this feature quite alot for importing classes, so its fairly annoying.
How can I fix this?
I'm on 4.1.2 running on Arch Linux, I don't want to break my gtk theme (as in change this in my theme. The theme works perfectly fine with all other applications on the workstation, and I don't want to compromise this).
[Updated on: Thu, 20 December 2012 09:19] by Moderator
Re: Where can I change the background colour of the suggestion popups? [message #992055 is a reply to message #991941] Thu, 20 December 2012 14:12 Go to previous messageGo to next message
On one side you could tweak the colors of your linux install, on the other side you can change lots of colors used in Eclipse in the Eclipse preference menu.
Preferences:
https://lh3.googleusercontent.com/-Z7zbELLkmVo/UNNifunVV6I/AAAAAAAAKdI/Ec0EKdHNoVs/s813/Color+1.png
Results:
https://lh4.googleusercontent.com/-wLFA_ZgtxiM/UNNiforIqjI/AAAAAAAAKdE/nSruBdKnvFY/s800/Color+2.png
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: Where can I change the background colour of the suggestion popups? [message #992136 is a reply to message #992055] Thu, 20 December 2012 19:17 Go to previous messageGo to next message
thank you very much for taking the time to make this detailed answer. Unfortunately, it doesn't work on Linux. I just checked, the change works fine on OSX, but does nothing on Linux. In the same way as the marketplace links doesn't work etc. etc. I suppose eclipse on Linux is not really a priority :/
Re: Where can I change the background colour of the suggestion popups? [message #992142 is a reply to message #992136] Thu, 20 December 2012 19:41 Go to previous message
I've resorted to changing appearance. For example, on Lucid (under
Gnome), I use Clearlooks.
Previous Topic:after import existing jsf project aplication not work
Next Topic:How to Install Plug-ins
Current Time: Sat Jul 26 07:45:42 EDT 2025
Powered by FUDForum. Page generated in 0.09738 seconds
