Home » Eclipse Projects » EclipseLink » entity extensions in a secondary table
entity extensions in a secondary table [message #987607] Tue, 27 November 2012 05:21 Go to next message
Is it possible to include the extension fields into another table and have property based access for those fields via a new extended secondary entity?
I am trying to avoid main table alter to support new fields/relationships and also have property based access for the extension fields.
Any thoughts?
Can we have a pojo to hold extensions instead of Map?
thanks,
Pradeep V.B.
[Updated on: Tue, 27 November 2012 05:49] by Moderator
Re: entity extensions in a secondary table [message #987695 is a reply to message #987607] Tue, 27 November 2012 11:13 Go to previous messageGo to next message
You can map extensions however you wish. You can put the mappings in any table, and can any implementation under your get/set methods you wish.
What have your tried, and what issue have you had?
Re: entity extensions in a secondary table [message #990638 is a reply to message #987695] Thu, 13 December 2012 09:39 Go to previous messageGo to next message
I was able to add new fields into the secondary table. My problem was to have property based access to the new fields. I dont want to use generic get/set methods for the extension fields. Is there a way to have proper getter/setter methods for the extended fields.
thanks,
Pradeep V.B.
Re: entity extensions in a secondary table [message #991516 is a reply to message #990638] Wed, 19 December 2012 11:15 Go to previous message
If you can add the get/set methods to your class, you can use them. If the get/set methods are not there, then I don't see how you can use them?
Perhaps give detail on exactly what you are trying to do.
Previous Topic:EclipseLink-7251: is mapped to a primary key column in the database. Updates are not allowed.
Next Topic:distinct keyword in batch fetch query
Current Time: Sun Jul 20 22:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.05516 seconds
