Managing separate model files [message #991176] |
Mon, 17 December 2012 10:39  |
I have created an EMF meta-model and associated editor in Graphiti.
I would now like to create a separate resource file (xmi) to store the associated model.
I have basic java experience but have no real experience in Eclipse GMF or Plugins.
When a new diagram is created, I would to be able to create a new (associated) model file. I can then add created objects as per tutorial.
Additionally, when an existing diagram is opened, I would like to load the associated model file.
I would really appreciate some guidance on how to achieve the above.
Many thanks,
Dan
Re: Managing separate model files [message #991207 is a reply to message #991176] |
Mon, 17 December 2012 13:18   |
On 17.12.12 07.39, Dan Simkins wrote:
> associated model.
> or Plugins.
Based on advice on this forum, I made a custom persistence behavior
class, along these lines:
public class ActorDiagramPersistencyBehavior extends
DefaultPersistencyBehavior {
public Diagram loadDiagram(URI uri) {
// load diagram
diagram = super.loadDiagram(uri);
// is it properly linked or not?
if (diagram != null) {
PictogramLink link = diagram.getLink();
if (link == null || link.getBusinessObjects().isEmpty())
ensureModelResource(diagram);
// create model with root object corresponding to diagram
protected Resource ensureModelResource(Diagram diagram) {
Resource diagramResource = diagram.eResource();
URI modelUri =
diagramResource.getURI().trimFileExtension().appendFileExtension("xactor");
ResourceSet resourceSet =
diagramEditor.getEditingDomain().getResourceSet();
Resource modelResource = ensureModelResource(modelUri, resourceSet);
Nameable modelRoot = ensureModelRoot(modelResource);
// try {
// modelResource.save(Collections.EMPTY_MAP);
// } catch (IOException e) {
// e.printStackTrace();
if (link == null) {
diagram.setLink(link = pictogramsFactory.createPictogramLink());
link.getBusinessObjects().add(modelRoot);
return modelResource;
private Nameable ensureModelRoot(Resource modelResource) {
// create the root object
String name = getModelRootName(modelResource.getURI());
Nameable modelRoot = null;
if (modelResource.getContents().isEmpty()) {
modelRoot = createModelRoot();
modelRoot.setName(name);
modelResource.getContents().add(modelRoot);
} else {
modelRoot = (Nameable) modelResource.getContents().get(0);
return modelRoot;
Note that since this is considered a change to the model, it needs to be
done in a write transaction, so I have actually created a Command object
as follows, that is executed the the editing domain's command stack:
private Command createModelRootCommand(final Diagram diagram) {
return new AbstractCommand() {
public boolean canExecute() {
return (link == null || link.getBusinessObjects().isEmpty());
return false;
public void execute() {
public void redo() {
public boolean canUndo() {
return false;
Hallvard
Re: Managing separate model files [message #992334 is a reply to message #991658] |
Fri, 21 December 2012 06:34  |
Hi Hallvard,
Thank you - you were correct; it was the fact that the wizard was launching the default DiagramEditor.
I have created and registered my own wizard which now launches my custom diagram editor.
Many thanks to Michael and yourself for assistance.
Kind regards
Dan
FUDForum. Page generated in 0.06141 seconds
