Unhandled event loop exception - nlsProject can not be null! [message #991279] |
Tue, 18 December 2012 05:28  |
Hello Community, its me again.
i Have a "Big" Problem with my Scout Framework.
On Operations like "New Page...", "New Form...", "New Menu..." and some more i get a 'Unhandled event loop exception' based on a 'java.lang.IllegalArgumentException: nlsProject can not be null!'
Has anyone a Tip how to fix that?
The Full Details are:
eclipse.buildId=M20120208-0800
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -showlocation -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -showlocation -data
Error
Tue Dec 18 11:11:40 CET 2012
at org.eclipse.scout.sdk.ui.fields.FieldToolkit.createNlsProposalTextField(FieldToolkit.java:66)
at org.eclipse.scout.sdk.ui.fields.FieldToolkit.createNlsProposalTextField(FieldToolkit.java:61)
at org.eclipse.scout.sdk.ui.wizard.page.PageNewAttributesWizardPage.createContent(PageNewAttributesWizardPage.java:93)
at org.eclipse.scout.sdk.ui.wizard.AbstractScoutWizardPage.createControl(AbstractScoutWizardPage.java:68)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:608)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.scout.sdk.ui.action.AbstractWizardAction.execute(AbstractWizardAction.java:45)
at org.eclipse.scout.sdk.ui.action.AbstractScoutHandler.execute(AbstractScoutHandler.java:150)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Kind regards
Kris
FUDForum. Page generated in 0.15659 seconds
