Buckminster and Emma No Coverage [message #990908] |
Fri, 14 December 2012 14:12  |
I'm using Buckminster to build my product headlessly. However, around mid November, it started to fail when running emma. I get the following error:
[java] INFO: Starting test session AllTests
[java] INFO: Running test org.archstudio.prolog.test.ProofTest2.testProof1...
[java] INFO: ...OK [2.857s]
[java] INFO: Running test org.archstudio.xarchadt.variability.XArchADTVariabilityImplTest.testOverviewWithDependent...
[java] INFO: ...OK [0.379s]
[java] INFO: Tests finished.
[java] INFO: Elapsed time: 51.399 seconds.
[java] INFO: Total number of tests executed: 64
[java] INFO: Successful tests: 64
[java] INFO: Failed tests: 0
[java] INFO: Errors: 0
[java] INFO: Ignored tests: 0
[java] INFO: Overall status: OK
[java] ERROR: No coverage has been collected during coverage launch (code 5101).
[java] org.eclipse.core.runtime.CoreException: No coverage sessions found.
[java] at org.eclipse.buckminster.runtime.BuckminsterException.fromMessage(BuckminsterException.java:57)
[java] at org.eclipse.buckminster.runtime.BuckminsterException.fromMessage(BuckminsterException.java:53)
[java] at org.eclipse.buckminster.emma.Emma.internalRun(Emma.java:101)
[java] at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
[java] at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:350)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:145)
[java] at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:165)
[java] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[java] No coverage sessions found.
According to here: http://www.eclemma.org/faq.html#trouble01 "This happens when the Java process did not terminate properly, e.g. has been manually killed with the Terminate button. Make sure your program terminates on its own."
But, my scripts are not terminating abnormally, as far as I know.
Any ideas?
Thank you,
-- Scott
Re: Buckminster and Emma No Coverage [message #991281 is a reply to message #990908] |
Tue, 18 December 2012 05:30   |
Not sure if it's related but the options for the emma command changed
slightly when we moved to eclemma 2.2.0 (mid November so the timing
seems just about right). In particular, the formats 'emma' and 'txt' are
no longer supported. Details can be found here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=368042
- thomas
On 2012-12-14 20:12, Scott Hendrickson wrote:
> error:
> (code 5101).
> found.
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> Method)
> [java] at
> [java] at
> [java] at
> [java] at
> Any ideas?
> Thank you,
> -- Scott
Re: Buckminster and Emma No Coverage [message #991432 is a reply to message #991281] |
Tue, 18 December 2012 23:29  |
Thanks Thomas,
Thank you for the potential cause, but I get the error whether I actually ask for the coverage report (using --xml) or not when I run the tests. So, I currently cannot run the tests at all.
-- Scott
FUDForum. Page generated in 0.16722 seconds
