Home » Eclipse Projects » Eclipse Scout » Unhandled event loop exception - nlsProject can not be null!(java.lang.IllegalArgumentException: nlsProject can not be null!)
Unhandled event loop exception - nlsProject can not be null! [message #991279] Tue, 18 December 2012 05:28 Go to next message
Hello Community, its me again.
i Have a "Big" Problem with my Scout Framework.
On Operations like "New Page...", "New Form...", "New Menu..." and some more i get a 'Unhandled event loop exception' based on a 'java.lang.IllegalArgumentException: nlsProject can not be null!'
Has anyone a Tip how to fix that?
The Full Details are:
eclipse.buildId=M20120208-0800
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments:  -showlocation -showlocation
Command-line arguments:  -os win32 -ws win32 -arch x86 -showlocation -data
Error
Tue Dec 18 11:11:40 CET 2012
	at org.eclipse.scout.sdk.ui.fields.FieldToolkit.createNlsProposalTextField(FieldToolkit.java:66)
	at org.eclipse.scout.sdk.ui.fields.FieldToolkit.createNlsProposalTextField(FieldToolkit.java:61)
	at org.eclipse.scout.sdk.ui.wizard.page.PageNewAttributesWizardPage.createContent(PageNewAttributesWizardPage.java:93)
	at org.eclipse.scout.sdk.ui.wizard.AbstractScoutWizardPage.createControl(AbstractScoutWizardPage.java:68)
	at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
	at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
	at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:608)
	at org.eclipse.jface.window.Window.create(Window.java:431)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
	at org.eclipse.jface.window.Window.open(Window.java:790)
	at org.eclipse.scout.sdk.ui.action.AbstractWizardAction.execute(AbstractWizardAction.java:45)
	at org.eclipse.scout.sdk.ui.action.AbstractScoutHandler.execute(AbstractScoutHandler.java:150)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Kind regards
Kris
Re: Unhandled event loop exception - nlsProject can not be null! [message #991291 is a reply to message #991279] Tue, 18 December 2012 06:41 Go to previous message
NLS is the support for internationalization.
Have you started a new project, or are you updating an old one to a new Scout version?
I recommend you to check the classes / files mentioned in the Juno migration guide for TextProvider and bug 361816.
Even if you do not come from an older version (like Indigo), check that you have not recently modified these files.
Previous Topic:Jax Webservice LogHandler
Next Topic:TCP KeepAlive in Scout Client
Current Time: Wed Jul 23 22:52:18 EDT 2025
Powered by FUDForum. Page generated in 0.05401 seconds
