No javadoc with Jdk 1.5 [message #99123] |
Fri, 02 September 2005 09:22  |
Originally posted by: javier.campoamor.net
I'm having a problem with Eclipse 3.1 with the Jdk1.5 because I'm unable to
see the Javadoc asociated with each method. When I change to the Jdk1.4.2
then I see the full javadoc again.
Do you know where can I configure the path to the javadoc?
Javier
Re: No javadoc with Jdk 1.5 [message #99837 is a reply to message #99123] |
Tue, 06 September 2005 12:11  |
Originally posted by: eclipse3.rizzoweb.com
Javier Campoamor wrote:
> Hello,
Do you mean for the JDK classes (java.lang.*, etc)? If so, the 1.5 JRE
that you have defined does not have a source attachment. The easiest way
is to include src.zip in the JDK 1.5 directory (you may have to restart
Eclipse and/or re-add the JDK 1.5 JRE within Eclipse preferences.
You can attach source manually by going to
Preferences > Java > Installed JREs, select the 1.5 JRE and click Edit.
Then uncheck the "use default libraries" checkbox, expand the entry for
rt.jar and edit it's source attachment.
HTH,
Eric
FUDForum. Page generated in 0.11560 seconds
