Issues with Kepler M4 and E4 Tools [message #991167] |
Mon, 17 December 2012 10:26  |
I just downloaded Kepler M4 and tried to import the e4 tools projects. The CSS editor and CSS editor UI are failing. Also it is not possible to install the CSS editor into Kepler M4.
After some research I've found out that Kepler M4 comes with a com.ibm.icu_50.1.0...
Can this be correct? In Kepler M3 it was com.ibm.icu_4.4.2...
This seems to be the cause for not being able to install the CSS editor. Xtext UI Core defines its dependency to com.ibm.icu like this
com.ibm.icu [4.0.0,5.0.0)
so 50.1 is not included.
Is it a workaround to change the bundle manually to 4.4.2 out of the M3?
Greez,
Dirk
FUDForum. Page generated in 0.43871 seconds
