Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Multi Java Annotations in the model (Java Annotations in the model )
Multi Java Annotations in the model [message #986398] Tue, 20 November 2012 05:30 Go to next message
I've specified in the model a java annotation.
If I insert more than one java annotation for node, TEXO considers only the first java annotation and the others are ignored.
Example:
index.php/fa/12445/0/
Generation Code:
	 * Returns the value of '<em><b>field2</b></em>' feature.
	 * <!-- begin-user-doc --> <!-- end-user-doc -->
	 * @return the value of '<em><b>field2</b></em>' feature
	 * @generated
	@Overview(Overview.DATE)
	public String getField2() {
		return field2;
code generation that I expect:
	 * @generated
	@Overview(Overview.TEXT)
		return field2;
Re: Multi Java Annotations in the model [message #986406 is a reply to message #986398] Tue, 20 November 2012 05:42 Go to previous messageGo to next message
Hi Gabriele,
The content of the eannotation is a large text field, so you can put them all in one eannotation, that will work.
But it is probably no work to add support for this, can you enter a bugzilla for this?
gr. Martin
> Example:
> Generation Code:
> * @generated
> return field2;
> * @generated
> return field2;
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Multi Java Annotations in the model [message #991125 is a reply to message #986406] Mon, 17 December 2012 07:26 Go to previous messageGo to next message
As a side node: the Java code you want to be generated won't be valid. You can't annotate something with the same annotation type more than once. You would need something like
@Overviews(@Overview(Overview.Date), @Overview(Overview.Text))
or
@Overview({Overview.Date, Overview.Text})
Re: Multi Java Annotations in the model [message #991128 is a reply to message #991125] Mon, 17 December 2012 07:38 Go to previous messageGo to next message
Andreas Brieg wrote on Mon, 17 December 2012 13:26
or
It is the second one as you can only have one optional value/attribute in a java annotation...
[Updated on: Mon, 17 December 2012 07:39] by Moderator
Re: Multi Java Annotations in the model [message #991131 is a reply to message #991128] Mon, 17 December 2012 07:45 Go to previous messageGo to next message
Hi Andreas,
Not sure which annotation/annotation type do you mean, is it related to Texo or to something else?
gr. Martin
>> or
The Netherlands
Re: Multi Java Annotations in the model [message #991138 is a reply to message #991131] Mon, 17 December 2012 08:15 Go to previous message
Ha Andreas,
Forget my question, I see now that you refer to (the invalid example in) the original question.
gr. Martin
On 12/17/2012 01:45 PM, Martin Taal wrote:
> Hi Andreas,
> gr. Martin
>>> or
The Netherlands
Previous Topic:NPE When Serializing with Texo
Next Topic:EMF + Texo + Xpand2
Current Time: Fri Jul 25 22:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.25202 seconds
